Posted September 5, 2017 I have a Ryzen 1700x shipping to me within the week, and was wondering if the +20c temp problem is still an issue? And if so, does it effect cpu fan speeds? If it's always reading that it's 20c hotter than it actually is, I imagine it's going to put things into jet-engine territory when actually doing anything stressful. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 5, 2017 Some how I managed to post in the wrong thread. Black Knight- Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming, Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon Daughter's Rig; MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 5, 2017 Author I'm not actually having issues at the moment, I'm just speculating and asking if the issue still exists with the +20c issue that I know was around when they first came out. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 5, 2017 it was made because amd's TJ max is 20 degrees lower than intel's, if that wasn't there amd cpus would overheat under certain scenarios, it shouldn't make things be in jet mode because ryzen cpus are very efficient and dont make much heat Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 5, 2017 13 minutes ago, asand1 said: I don't know what max RPM in that fan, but you could try speedfan to create a custom curve. 15 minutes ago, Draydince said: I have a Ryzen 1700x shipping to me within the week, and was wondering if the +20c temp problem is still an issue? And if so, does it effect cpu fan speeds? If it's always reading that it's 20c hotter than it actually is, I imagine it's going to put things into jet-engine territory when actually doing anything stressful. I believe the issue has been fixed in software by most manufacturers and software devs, certainly the most popular temp sensing apps now offset to adjust for the issue. The best advice is if you don't believe the reading your getting then double check in another app, if it was me then I'd triple check it anyway even if it seems believable. Main Rig:- Ryzen 7 3800X | Asus ROG Strix X570-F Gaming | 16GB Team Group Dark Pro 3600Mhz | Corsair MP600 1TB PCIe Gen 4 | Sapphire 5700 XT Pulse | Corsair H115i Platinum | WD Black 1TB | WD Green 4TB | EVGA SuperNOVA G3 650W | Asus TUF GT501 | Samsung C27HG70 1440p 144hz HDR FreeSync 2 | Ubuntu 20.04.2 LTS | Server:- Intel NUC running Server 2019 + Synology DSM218+ with 2 x 4TB Toshiba NAS Ready HDDs (RAID0) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 5, 2017 Author Cool, glad to hear it. I usually use both HWMonitor and Realtemp to make sure the readings are similar to eachother. Thanks for informing me. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
