Does Ambient Temp Make A Difference?
Solved by Lurick,
1 minute ago, xovague said:So since my ambient temp is now 20+ degrees hotter than I'm use to having it at, I'm showing a 20+ degree increase? So I probably did achieve the 20C drop with the delid but I won't be able to tell till I get the A/C fixed?
If your ambient temps went up by 20C then your max and min temps will go up by 20C.
So once you get the AC fixed and remove that 20C increase in ambient temps then you'll probably see temps around 54C
