Um.... Thats amazing? 120 is way faster than most peoples download speeds. You will never really NEED that unless you upload a ton of stuff or have many many many game servers.
Specs:
 Gaming PC: i5 3570, 16GB 1600MHz, GTX 780 3GB, Transcend 128GB, WD 500GB, Seagate 500GB, Thermaltake 600W Smart, S340 w/ RGB, Windows 10 Pro
 Server: Xeon E5 2650, 12GB 1600MHz ECC, 8400GS, WD 2TB + 1TB + 1TB, EVGA 500B 500W, Windows 10 Pro
 Laptop: Macbook Pro Retina 2013, i7 4558U, 8GB 1600MHz, Intel Iris Pro 1.5GB, Apple 256GB NVME, Mojave
 Internet: $70/month For 500/100, Actually get 525/102
https://linustechtips.com/topic/829282-internet-speed/#findComment-10376895
Depends on what you are paying for. 120 mbps is a perfectly good upload speed. I would find your bill from your ISP and see what you are paying for. It sounds like you are on a fiber connection which is usually symmetrical. For instance I have a 1Gbps up/down connection for my fiber.
https://linustechtips.com/topic/829282-internet-speed/#findComment-10376897
I found that I have symmetrical upload and download when using ethernet but not when using wifi, so this might depend on the router as well.
https://linustechtips.com/topic/829282-internet-speed/#findComment-10376915
Yes it definitely will depend on your router. Plus there is what we call 'overhead' you will never really get 'full speed' , you'll always miss about 10% or maybe a little more depending on the caliber of your networking equipment.
https://linustechtips.com/topic/829282-internet-speed/#findComment-10376933
you have god tier internet... i would literally kill you and take your place as part of your family to have that....
jk...
but i do really want internet like that. xD
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
https://linustechtips.com/topic/829282-internet-speed/#findComment-10376949
That's an amazing speed. Why would you think that it's bad?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/829282-internet-speed/#findComment-10376972
Is this a showoff post?
Most companies don't even have these speeds upload and downloads. Sure the big ones as they afford the high price, but smaller ones, no way.
Most people dream for 30mbps DOWNLOAD.
If the internet is "slow" for you, then it is the website you are connected to that doesn't have as fast speeds as you, or is busy.
https://linustechtips.com/topic/829282-internet-speed/#findComment-10376974
No its just I dont really understand internet speeds all too well and when i mention my internet speed to people i know they say. "Aw thats not very fast." And we pay quite a bit for it so i was concerned that i wasnt getting what i paid for.
https://linustechtips.com/topic/829282-internet-speed/#findComment-10376980
Go to Speedtest and post the result here.
Main System: Phobos
https://linustechtips.com/topic/829282-internet-speed/#findComment-10376984
Well, what is your plan? If you paid for those speeds, then you are getting what you are paying for.
https://linustechtips.com/topic/829282-internet-speed/#findComment-10376989
Wi-Fi is half-duplex. So there's going to be an imbalance between uploads and downloads.
https://linustechtips.com/topic/829282-internet-speed/#findComment-10377001
Yes but why is there close to an 800 mbps diffrence it seems strange. Also on lan.
That's what you pay for then. It doesn't have to be the same, and upload speed is often far lower than download speed.
Main System: Phobos
https://linustechtips.com/topic/829282-internet-speed/#findComment-10377010
I mean, WOW, my download speed is like 500kbps and i don't get it for cheap either, i feel ashamed...
Project Diesel 5.0: Motherboard: ASRock Fatal1ty X370 Professional Gaming /// CPU: Ryzen 5 3600X  /// CPU Cooler: Scythe Ninja 5 /// GPU: Zotac AMP Extreme RTX 2070 /// RAM: 2x 16gb G.Skill Ripjaws V @3200mhz /// Chassis: Lian Li Lancool One Digital (black) /// PSU: Super Flower Leadex III 750w /// Storage: Inland Premium 1TB NVME + Toshiba X300 4TB
Peripherals: Mice: Cooler Master MM720 /// Keyboard: Corsair K70 MK2 SE (Cherry Silver), Blitzwolf BW-KB1 (Gateron Reds) /// Monitor: Acer XZ320Q 32' (VA, 1080p @240hz) /// AMP: Topping PA3 (Onkyo Integra A-817XD undergoing restoration) /// DAC: Weiliang SU5 /// Speakers: AAT BSF-100 /// Mike: Alctron CS35U /// Headphones: Blon B8, ISK MDH-9000
Living room: TV: Samsung QLED Q7FN 55' 4k /// Amplifier: Denon AVR-X2400H /// Speakers: DALI Zensor 7 /// Consoles: Sony PS4 Pro 1TB, Sony PS3 500gb /// LD/CD/DVD: Pioneer DVL-909 /// Power Supplies: Upsai ACF-2100T + GR Savage CDR2200EX
https://linustechtips.com/topic/829282-internet-speed/#findComment-10377019
At the bottom you can see this is the fastest internet money can buy via cable in Quebec:
http://www.videotron.com/residential/internet/residential-internet#
And here on the right, via fiber. Direct home fiber connection
http://www.bell.ca/Bell_Internet/Internet_access
Here are a graph showing an avg speed per province:
543355-fisp-2017-canada-provinces.png?th
https://linustechtips.com/topic/829282-internet-speed/#findComment-10377026
5 minutes ago, Topzombie22 said:
Well its supposed to be half of my download.
So let's just say your ISP advertises 500Mbps down and whatever up, yet you're getting 900Mbps down. And you're worried you're not getting the internet speed you're paying for because people think it's slow?
I don't think I've found a better time to drop the phrase "first world problem" than now.
https://linustechtips.com/topic/829282-internet-speed/#findComment-10377040
Just now, M.Yurizaki said:
So let's just say your ISP advertises 500Mbps down and whatever up, yet you're getting 900Mbps down. And you're worried you're not getting the internet speed you're paying for?
See i ment the upload is supposed to be half of the download but apparently on their site it is not even though I was told otherwise.
https://linustechtips.com/topic/829282-internet-speed/#findComment-10377045
Well, give them a call and ask why that is.
https://linustechtips.com/topic/829282-internet-speed/#findComment-10377050
