Hourly but it depends on how much work is involved. If it's a huge disaster then maybe charge a bit more but still within reason. If the cabling isn't terrible then maybe you could get away with a flat fee instead but if you're talking several days then charge by the hour, explain why, and lay it out so they know you aren't trying to just rip them off.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
What is a good starting price to charge? This is the cable mess.
21244817_1311168525659357_90165079_n.png?oh=44fdae0b9b3db19679c3fbb54dbb849c&oe=59A86DE0
"Just another day at the office" Captain Price -Call of Duty
That's maybe a few hours of work, a day at most. Charge what you think is reasonable, not sure the area so the going rates could be different.
I was imagining much worse :P
Prior Build Log/PC:
I recently did a bigger job but at work so I couldn't charge them.
20 minutes ago, Matthew45985 said:
Hello! I am doing my first business networking job. I have to reorganize and fix the layout of the rack. I was wondering if I should charge by the hour or just a flat rate?
Thanks,
Matthew
What i would quote for is 2.5 days of work and proper brackets, shelves for equipment, and lots of cable ties. You will look more professional giving a quote; keeping to it and finishing on time.
That's exactly what I ordered yesterday. You read my mind.
lol that rack - the only thing actually mounted are the PDU's, UPS and the Patch panel.
make sure you charge them well for some rack ears to mount those switches :P
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
I have a spare 48 port Dell Powerconnect Switch that I plan to use.
Honestly quote them for a day longer than you think it would take just in case you encounter something that takes you longer than expected to do. Honestly explain it to them what needs to be done and If you finish it earlier than you tell them it makes them happy. But that''s my two cents
