What case do i have?
RoxBox
Go to solution Solved by Yar,
Looks like a Lian Li PC-OSX.
o6s-f-00
What case is this?
Im curious because my friend was building a pc for my other friend and got mad cuz he couldnt get it to post with the i7 (he had no cooler on it ×.× fried it.) And he took everything out and threw the case off the 2 story deck... Well i went to go grab it and i asked him if i could have it. He said yeah. I cant find a model number anywhere so im at a dead stop. Ill add some pictures.
Dang. your friend seems a bit... dull...
As for the case - nearly all of the pictures are blurry - making it hard to tell.
Are there any letters on the case at all?
Perhaps the most useful image (if there are no words/model #s)  would be a closer picture of the case's front panel.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
3 minutes ago, RoxBox said:
Sure. Is this good enough?
Is there any branding on it at all?
sudo chmod -R 000 /*
you really shouldn't have the unshielded magnet of the SUB that close to your pc!!!!!!!!
Intel Xeon X5650 OC'd to 4Ghz  Sapphire R9 290 Vapor X 4GB  |  Vengeance® K70 & M65  W10 Pro
I don't think he needs to worry about erasing his floppies. :D
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
Any ideas as to what case it is?
No branding at all.
No branding at all.
Nope, no idea. Can't find anything similar. Can you ask your friend where he bought it?
It was given to him so i dont think he knows either..
Do you think it might be one of a kind?
