CPU choice with limited cooling
Solved by Berfs1,
Consider waiting for 8th gen, as the i7-8700K may be worth your look. It will have 6C12T, 12MB L3 Cache, rumored 95W TDP, and rumored 4.3GHz turbo on six cores, all apparently at 95W. IF that reading is true, you may have yourself a really fast chip! If not, you can always go for the 8700 for 100MHz lower single core frequency (4.7 to 4.6) at 30W lower TDP (95W to 65W). All, with DDR4 2666 ram support (apparently only the i7s will support 2666, the i3s and i5s will support 2400 apparently). The reason I am not saying anything about Kaby Lake is because they aren't, in my view, recommended chips anymore; the i3 8350K will beat all of those single handedly with an overclock, at half the price of the 7700K.
