Best nintendo switch backup power
bughtoo
Looking for a powerbank that will give my switch extra juice for long journeys.
Price - irellevant
Capacity - bigger = better
Requirements - must charge faster/as fast as it discharges when playing a game
Size - smaller than switch without controllers
Any ideas?
ASUS Maximus VII Hero | i7 4790K OC 4.8GHZ | 4x8GB 2400MHz MSI GTX 1070 alphacool eiswolf gpx pro
Samsung 850 EVO 520GB + Corsair 525gb + 275gb SSD  2TB Seagate Barracuda | 8TB Seagate Archive
Cooler Master HAF-X 942 | EVGA Supernova 1000W 80+ Platinum | Custom watercooling loop (gpu+cpu)
360mm+180mm rad and 10 fans | Swiftech D5 mcp655-B
1 hour ago, Pixel5 said:
one big limitation of this one is that it has over 100Wh capacity so you will not be allowed to take this one on a plane with you.
what is the conversion? because even that one ravpower has over 100 or?
But still it doesnt matter to me i dont fly that often, more often i go by train :)
the other one actually has 99,16Wh to stay just below the 100Wh limit
the calculation is simply capacity in Ah times the voltage which in this case is 3.7V
Wh is the only unit that really makes it possible to compare the capacity of the battery packs as you could have a pack with 15000mAh but at 7,4V which would have the same amount of energy as the one you posted before but since people only look at big numbers everyone is using 3,7V to boost their mAh ratings.
Okey, good to know :) Flying is not a problem for me though, thanks for the information!
