Those are the actual Wifi antennae. Generally, high quality Wifi cards have antennae that are external to the card itself (and sometimes the device).
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
https://linustechtips.com/topic/824006-strange-wifi-card/#findComment-10320786
If I put them on my custom build, where would I put these antennas? Theyre very fragile.
https://linustechtips.com/topic/824006-strange-wifi-card/#findComment-10320794
Those are just the external antennae for the wifi card, they route outside the case and probably under some thin plastic paneling to get you maximum connectivity.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/824006-strange-wifi-card/#findComment-10320795
Outside the case is the best option. They'll pick up noise from other components in the case and the case can work like an RF cage, limiting or disallowing connectivity range and/or throughput.
Come Bloody Angel
Pale battered body
Fierce Bloody Angel
Pyo.
https://linustechtips.com/topic/824006-strange-wifi-card/#findComment-10320799
You could feasibly put them anywhere, but if they are fragile enough that you might damage them simply by removing them or having them exposed, then it might be best to invest 25$ on a better wifi card :3
https://linustechtips.com/topic/824006-strange-wifi-card/#findComment-10320801
thats normal. like @Drak3 said, a lot of wifi cards have wifi antennae set up that way. especailly lower end prebuilts, and laptops as well(laptops actually have these wires running up by the display).
best place would be the outside of the case, maybe taped onto the side or the top. however i would sugget getting a better wireless card that has normal external antennae
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/824006-strange-wifi-card/#findComment-10320802
Thanks for the info but I think it wont work. It was in a slot called PCIE-Mini and wont fit inside any PCIE.
https://linustechtips.com/topic/824006-strange-wifi-card/#findComment-10320839
Not surprising it's something you normally find in laptops.
Just go to Amazon and get a tp-link Wi-Fi card for 15-20$
https://linustechtips.com/topic/824006-strange-wifi-card/#findComment-10321683
Or buy an adapter with built in external antenna: https://www.amazon.com/HOTER-Mini-Wireless-adapter-antenna/dp/B004TIK8UG
https://linustechtips.com/topic/824006-strange-wifi-card/#findComment-10323727
