Best fan for 212 evo
LintenSteel
I need help with finding the best asus arua sync compatible rgb fan for my hyper 212 Evo my CPU is the r5 1600 that I'm going to overclock any help is appreciated
The stock cooler is as good as the 212. Get something better. An RGB fan would cost as much as the cooler itself. Just forget RGB and get a better cooler.
Look here :)
http://www.overclock.net/t/1274407/fans-the-most-complete-and-comprehensive-array-of-tests-and-benchmarks
Specs
i9 9900K 5.1GHz 0 AVX offset
ASUS MAXIMUS APEX XI
Custom watercooling (360mm, 60mm thicc)
EVGA GTX1080 FTW DT
EVGA T2 1000W Platinum PSU
3200MHz G.Skill RGB B-die
Samsung 970 Pro 512GB
Samsung 860 EVO 2TB
Crucial MX300 1TB
Lol, you don't replace the fan on a cheap budget air cooler, it 100% defeats the purpose cost wise as you could have gotten a better cooler all together.
Edit: If you must RGB, I believe AMD is going to sell their coolers stand alone now, RGB tax and all.
1 minute ago, ravenshrike said:
...Those benches are useless unless you run all your fans at 100%.
Specs
EVGA GTX1080 FTW DT
Samsung 860 EVO 2TB
Crucial MX300 1TB
2 minutes ago, Klovnious said:
Noise and airflow curves are not equal at all RPMs.
He is planning to overclock his CPU, chances are his fans are going to spin at a higher RPM anyways.
Specs
EVGA GTX1080 FTW DT
Samsung 860 EVO 2TB
Crucial MX300 1TB
