lavasoft leftovers / no connection
hello
for some strange reason lavasoft webcompanion was preinstalled with a downloaded win 10 version from piratebay ,i unistalled the app immidiately because i didnt knew what this is
after few weeks (today) i decided to delete the leftovers some sort of (lavasofttcp.dll , lavasofttcp.ini etc) files after removing it some apps like skype and steam couildnt connect to the internet although i had a working internet connection and browsing the internet via chrome was good
everytime i launch steam i get this message
any help?
https://linustechtips.com/topic/820536-lavasoft-leftovers-no-connection/
Why would you download Windows 10 from TPB?
Sounds like you deleted something important that was baked into the copy you downloaded.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
i restored the files and now they working
but im thinking that this could be a virus or something?
Yes, there is no reason to download Windows 10 from anywhere other than Microsoft.
It's free to download and make an installer and you can get a key for like $20.
I would suggest you make a bootable media from here and reinstall from scratch:
https://www.microsoft.com/en-us/software-download/windows10
Prior Build Log/PC:
already did that
i just need to wait until exams are over so i dont lose everything during the process and then ill install it
Essentially this lavasoft crap is being injected into the steam process, and it has been identified that it is injected
Steam have a list of conflicting programs with their downloader, and DLL injectors usually mean you can't connect to vac servers when needed
idk
Just reinstall Windows with an official image from Microsoft and use that, even if it isn't activated.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
