Good Air Cooler
Solved by Monti,
Buy it from Amazon http://www.amazon.com/Cooler-Master-Hyper-212-RR-212E-20PK-R2/dp/B005O65JXI
And if you're only using them for case fans then apart from silence and looks there won't be a noticable effect.
the benefit of ordering from Newegg isn't worth the compromise you'll make for another sub 40$ cooler.
just buy it from amazon
Ok thanks for the really fast replies. I will order it and thank you.
