A few questions about expanding Swiftech H240X
Solved by Napper198,
I run the original waterblock, an EK Titan Pascal and an additional 360 rad on it and I'm still fine with just 25% PWM power on it.
If you don't change the tube size and if you're fine with having 2 barb fittings then you don't need to change anything, but if you want to change one thing you'll need the adapter and 2 G1/4 fittings for that. The adapter just gives you a standard G1/4 thread on the pump like the one in the red circle.
