2 front intake140 mm fan + one rear exhaust 120mm = ok?
shooter2749
If you're going for positive airflow pressure, then sure, you should be fine.
but will it be too much intake airflow?
There's not really anything like TOO MUCH AIRFLOW. The air can't do anything to hurt your parts unless you leave a pile of dust in front of the intakes. I personally have 6 intake fans and 2 output fans *shrug* no problems 1.5 years along, but I do need to dust it off sometime soon.
:D Where you have read/heard things like that? No, thats refered as optimal situation. LTT has made video about it which confirms it:
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
