GPU and Display Question
Solved by LyondellBasell,
1 hour ago, M.Yurizaki said:There are several issues here:
- I'm getting different answers, but the GTX 1080 is likely only able to support up to four displays.
- It may not allow for Surround Mode if you have more than three displays
- There's only one HDMI output and a DVI output, which can passively convert to HDMI. The third TV will need a DP to HDMI converter, which may cause issues.
- There's also some combination quirk I keep vaguely remembering, like if you use two DP you can only use either the HDMI or DVI, not both.
i.e., I don't think what you're doing is possible.
As Yurizaki pointed out, the intended setup is far from ideal.
I suggest skipping the triple-TV sale, and instead buying 1 ultrawide.
You'll keep the simplicity of two panels, but gain that more desirable aspect ratio for looking into your corners. Plus you can just drive both displays directly off DisplayPort.
