Posted August 4, 2017 So Ryzen 7 has been out for over 5 months now and all the reviewers were sent a nice wooden box containing the review samples. My question is why hasn't anyone, especially LTT, built a Ryzen mini itx or even a micro atx PC inside the box? Sort of like Luke's awesome fallout 4 bomb build. From my rough calculations a mini itx build would easily fit and micro atx may even be possible, hell you could jam a custom water cooling loop in there and crossfire rx580's if you really wanted too. Add a space efficient PSU like the SilverStone SFX-L 800W Titanium which should have enough juice to power it all, and you would have the ultimate AMD build!! If they want to keep things fresh they could also do a full atx build inside the new AMD threadripper review box, (which appears to be a pelican case) complete with custom liquid cooling and crossfire Vega gpu's of course . Does anyone else want to see a build like this? Or is there a good reason why this kind of build hasn't been done before? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 That would be awesome. However, it would be very hard to put together since you would have to do a lot of custom work. But for a tech youtuber that would be a great video. Also, Linus' unboxing of threadripper is on the ltt twitter. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 Author @smheer Yeah it wouldn't be easy, but it would make a great video. 14 minutes ago, smheer said: Also, Linus' unboxing of threadripper is on the ltt twitter. Thanks, I didn't realize that their threadripper unboxing was on twitter, I almost thought that Linus had lost his unboxing king crown . Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 It would be cool if they did this. I would watch it. CORSAIR RIPPER: AMD 3970X - 3080TI & 2080TI - 64GB Ram - 2.5TB NVME SSD's - 35" G-Sync 120hz 1440P MFB (Mining/Folding/Boinc): AMD 1600 - 3080 & 1080Ti - 16GB Ram - 240GB SSD Dell OPTIPLEX: Intel i5 6500 - 8GB Ram - 256GB SSD PC & CONSOLE GAMER Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 i dont like it Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 Do you think Linus will do it? Spoiler linus cant do it Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 Author 1 hour ago, 3r4yd3n is weird said: I dont like it. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 8 minutes ago, |3r4yd3n said: Wow '3r4yd3n is weird', I can't believe you took the time to spell my username wrong. It's |3r4d3n by the way, maybe you should find out what 1337 (or leet for you) even is, before you go starting a flame war! I know why you don't like this idea it's because your just an intel fanboy and can't stand how much everyone likes Ryzen! Or is it because you just wish you had a Ryzen 7 cpu instead of a puny quad core i7 for rendering them videos. P.S. I know where you live! P.P.S Good one Zac, you nearly had me there . What the fresh fuck Main build: Intel Xeon E3 1240 | 16GB Avexir Red | Custom GTX 1050Ti | 1.5TB RAID0 | 500GB RAID0 | 240GB SSD | 240mm AiO | Thermaltake Dragonscale | Corsair CX600 v1 Media Center: Intel i5 3470 | 8GB Corsair XMS3 | GTX 550Ti XLR8 RED | 500GB WD Blue | Stock Intel | Dell 3010 Case | 250W PSU Main Laptop: Gold HP DV7 1127CL | AMD Turion X2 RM-72 | 4GB DDR2 | AMD HD 3200M Graphics | 32GB Hually SSD | 1TB Western Digital Blue Backup Laptop: Intel C2M T7200 | 4GB DDR2 | AMD X1600 Graphics | 160GB Seagate Momentus Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 3 minutes ago, H0R53 said: What the fresh fuck FRESH NEW DISCUSSION THAT YOU'LL ONLY FIND ON THE LTT FORUMS I'd much rather see some new Ryzen builds with that LTT flair and piazzas. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 ITS NOT POSSIBLE TO BUILD AN ENTIRE PC INSIDE OF A REVIEW BOX!! It wouldnt fit!! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 Author 8 minutes ago, 3r4yd3n is weird said: ITS NOT POSSIBLE TO BUILD AN ENTIRE PC INSIDE OF A REVIEW BOX!! It wouldnt fit!! Are you unaware of either the dimensions of the review box or those of the PC components required for this kind of build? The dimensions of the review box are hard to guess exactly but it came with a full ATX x370 motherboard inside of it for the reviewers to use for their testing. So it should easily fit a mini ITX or micro ATX motherboard according to my above test fit photo with room left for the PSU, GPU's and CPU cooler. Also @3r4yd3n is weird maybe you would like to watch the fallout 4 bomb build that Luke did a while back, now that shows how small of a case you can build a PC in and it still look awesome. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 Don't you know they have to send those review boxes back AMD would never allow them to destroy a review box like that. It would probably overheat and blow up! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 5, 2017 Author 20 hours ago, 3r4yd3n is weird said: Don't you know they have to send those review boxes back I don't believe the review kits are to be sent back especially since the pelican case that threadripper was sent in has the reviewers brand engraved on it. 20 hours ago, 3r4yd3n is weird said: AMD would never allow them to destroy a review box like that. I disagree, AMD would likely welcome the idea as a free promotion of their products. 20 hours ago, 3r4yd3n is weird said: It would probably overheat and blow up! Well the box would obviously need holes cut into it to provide sufficient airflow for cooling. Also what kind of explosives do you think an AMD review box is made of that would cause it to blow up . Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 5, 2017 No, what he should do is use a raspberry pi and a small screen to create a loop of the eye of Sauron in the TR box. Then have a 24/7 livestream of the box. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 5, 2017 Author 13 hours ago, ravenshrike said: No, what he should do is use a raspberry pi and a small screen to create a loop of the eye of Sauron in the TR box. Then have a 24/7 livestream of the box. Ok, maybe you should start a campaign for that. It would actually look pretty cool. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
