Best Blower GTX 1080/TI
jb600
Hey all,
Looking for your opinion on the best blower GTX 1080 or TI. Theres the founders edition but other manufacturers have their own blowers too, though not many... Asus has their Turbo for example.
Won't be doing any overclocking, or very little of it. Doing a HTPC build with either a GD09B or smaller, so having a blower style GPU is the way to go I think...
Thoughts?
A blower is a blower...
Not much gonna change other than a metal outer shroud.
MAD-BOX Ryzen 1600X - ASRock X370 Killer SLI - Sapphire R9 Fury NITRO+  -Fried it... RIP
Xeon e5640 4.35ghz, CoolerMaster Seidon 240V, ASUS P6X58D-E, DDR3 8GB 1636mhz CL9, Sapphire Fury Nitro OC+, 2x Stone age storage @ 7200RPM, Crucial 960GB SSD, NZXT S340, Silverstone Strider Gold Evolution, Steelseries RIVAL, Mechanical Metal keyboard, Boogie Bug Aimb mouse pad.
Moreso looking at peoples experiences with temps and overall performance
2 minutes ago, jb600 said:
Hey all,
Thoughts?
any you can find closest to the MSRP. AFAIK blower style cards are Founder's Editions with non-nvidia heatsinks. So any third party maker should perform ever so slightly better/cooler.
Streambox / Renderbox
AMD Ryzen 7 2700X Stock
AMD Wraith Max cpu cooler,
EVGA GTX 1070 Ti SC Black stock
16GB (2x8GB) G.Skill TridentZ DDR4 3600c15 @  2133MT/s stock
Asus x470 Crosshair VII Hero (WiFi)
EVGA T2 850w Gold Power Supply,
Samsung 860 Evo 500gb SSD4TB RAID-5 drive,
Cooler Master HAF XB Evo
ASUS ROG PG248Q,
w/ Razer Blackwidow Chroma V2, Razer Mamba Elite, Razer Goliath chroma
Main Machine / Gaming Machine
Intel Core i7-8086k @ 5GHz 1.35v,
Corsair H115i Pro, ROG Maximus X Hero WiFi, Samsung 960 Pro 512GB SSD,
ASUS Strix GTX 1080 Ti w/ NZXT G12 GPU & NZXT Kraken x42 140mm AIO,  G. Skill Trident Z RGB 32GB 3200MHz 14-14-14-34 1.35v,
Samsung 850 Evo 1TB SSD, WD Black 2TB HDD, WD Red 4TB HDD, Seasonic Prime 1000w Titanium PSU,  (3x) Corsair ML140 Pro,
Dell S2417DG,
Razer Blackwidow TE, Razer Lancehead, Razer Firefly,
Cooler Master H500P Mesh White
don't go for a blower style card.
you will overheat, and it will make tons of noise. if noise is important at all to you, don't get a blower card, especially for such a hungry card.
if there's room, maybe try a hybrid card, or use a kraken G12.
if there isn't room, then I'd personally just get a normal card, and run my case fans a bit faster to cycle the air more.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
Nope, aftermarket blower are the cheapest they can get away with.
Or slightly worse generally.
Want to custom loop?  Ask me more if you are curious
19 minutes ago, jb600 said:
Hey all,
Thoughts?
the TI cards without the DVI ports on them supposedly have better cooling due to less restriction on the exhaust (founders cards have this across the board). Founders cards also, supposedly, have some kind of advanced blower cooler design... some "vapor chamber" cooling design ... forget what the marketing team called the rubbish this time.... but my money on the best blower cooler based on that information would be the Founders cooler, but probably not majorly so compared to a cheaper variant like the Asus turbo... most of the crap like that is just marketing fluff and probably doesn't make a ton of real-world difference but i've also never really looked into it.
My 1080 Ti Founders is absolutely fine with a custom fan curve, it mostly stays at 78C under 100% load. I'd get that from a manufacturer such as EVGA (cuz warranty) and because the FE looks 100 times better than the other blowers, tbh.
Cheapest one.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
  • 2 months later...
And the fact that basically all 1080ti founders are out of stock so get the asus turbo or the zotac blower
  • 5 months later...
the PNY 1080Ti Blower Edition seems to be one of the cheapest available, and also looks to have more and bigger exhaust holes.
note: i did say "looks" because i found no specific benchmarks about this card
