Help. Lended my PC and now its broken
VictorianReaper
Go to solution Solved by LienusLateTips,
Reinstall windows.
So recently I lended my PC to a friend and he returns it to me in a seemingly good state so I go to boot it up and zilch
As in my computer doesn't do anything when I turn it on. The gpu is plugged into the monitor
While writing my post I contacted him finally and turns out he redirected my program files from C to F drive
Any clues please I'm not in a financial state to re buy most of my stuff
Dendrotoxin
CPU: i5 6600k @ 4Ghz | GPU: Zotac AMP! 1070 @ 2GHz | RAM Crucial Balistix 2x4GB | PSU EVGA G2 750w | Cooler: NZXT Kraken x61 | Case Phanteks Eclipse P400s | Motherboard Gigabyte G1 Gaming Z170 | Storage: Toshiba 3TB HDD and MyDigitalSSD M.2 256GB
Perripherals
Keyboard(s) Razer Ornata Chroma, Razer Tartarus Chroma | Mouse: Logitech G502 Spectrum | Headphone: Audio Technica M40x | Monitor HP 22CWA
Reinstall windows.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Just now, NinJake said:
Well for 1, your friend is a jerk.
2... did he just change the boot device or what?
Full Specs
Helios EVO (Main):
Delta - Laptop
No just program files
From what he said
Dendrotoxin
Perripherals
try going into the boot menu of your motherboard and switching the boot drive
1 minute ago, JDE said:
Reinstall windows.
How can I do that. I plugged in my monitor and get 'no signal'
Dendrotoxin
Perripherals
tell your friend that he is an idiot and never let him near your system again, or whats left of it
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 9 3900X|  |Cooling: Enermax Liquimax III, 6x 120mm Noctua Redux|  |Motherboard:  MSI MPG B550 Gaming Plus|  |RAM: 4x32gb 3200 G.Skill TridentZ NEO|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: Corsair CX-M 750W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb WD BLACK NVMe, 500gb NVMe, 1Tb Samsung 850 EVO|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G203 LIGHTSYNC|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
Doesn't work like that.
Full Specs
Helios EVO (Main):
Delta - Laptop
Do you have another computer? Any old or weak laptop will do. Or something powerful.
Full Specs
Helios EVO (Main):
Delta - Laptop
I have a laptop yes Lenovo 700
Dendrotoxin
Perripherals
Try and ask him for the hard drive he used, and then move back your program files.
plug drive into another computer, back up all the important shit and reinstall windows
My Stuff n' Things
can you plug the display cable into the motherboard?
What OS?
Full Specs
Helios EVO (Main):
Delta - Laptop
Just now, JDE said:
What OS?
Windows 10
Dendrotoxin
Perripherals
1 minute ago, VictorianReaper said:
Windows 10
https://www.microsoft.com/en-ca/software-download/windows10
Go there, get the installation tool, get a USB, make the installation media to the USB, plug USB into desktop once it's done, select to boot from USB, follow instructions.
BTW keep your files or else they will be deleted.
Full Specs
Helios EVO (Main):
Delta - Laptop
I already had one. I'll update with the results
Also where should my TV be plugged into MB or graphics card
Dendrotoxin
Perripherals
GPU
Full Specs
Helios EVO (Main):
Delta - Laptop
Caution: Reinstalling Windows WILL delete your data.
i5 6600k and GTX 1070 but I play 1600-900. 1440p BABY!
Still, don't put too much faith in my buying decisions. xD
What about unpluging a drive prior to installation
Dendrotoxin
Perripherals
That drive will not be affected then. That's what I do just to be safe. of course, and data on that drive that relies on data from the other drive is fucked. but documents should be fine.
Ok thanks
Dendrotoxin
Perripherals
I'm prompted for the type of installation I want. Which do I choose? Upgrade and keeps setting and files or Custom Windows only install?
Dendrotoxin
Perripherals
Upgrade to keep files.
Full Specs
Helios EVO (Main):
Delta - Laptop
