1400 + 1060 6gb. First of all, for gaming, it's better for the GPU to be better than the CPU. Secondly, you cant get a 580. They are out of stock.
Desktop benching:
https://linustechtips.com/topic/815360-please-help-me/#findComment-10227919
BS.
https://www.newegg.com/Product/Product.aspx?Item=N82E16814150797
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/815360-please-help-me/#findComment-10227962
The combination Jurrino recommended is great,but it just doesn't fit in my budget (€700).
1400=160 1060 6gb=€280
That makes €440,which is €40 over my budget.
Thanks anyway.
I wanted to buy a used r9 290/390,but there have been 3 (!) scammers for graphics cards on Marktplaats (dutch version of ebay) in 4 days,so I'm not sure if I want to buy secondhand.
https://linustechtips.com/topic/815360-please-help-me/#findComment-10227978
21 minutes ago, Yasin40 said:
Hi,I want to build a new PC.
I'm wondering of I should go with a Ryzen 3 1200 with an RX580 8GB or a Ryzen 5 1600 and a GTX1050Ti.
My main purpose for this PC will be gaming.
My budget for the CPU+GPU (combined) is €400,and I want an AMD CPU.
Thanks in advance.
I mean the 580 is a better card but the 1600 is a better cpu it really all depends on what you plan on doing with the pc.
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/815360-please-help-me/#findComment-10227991
