Hi, This is my first post here.  I just built my first computer yesterday.  after it was finished, I booted up, but nothing came on the screen (I am connecting hdmi from my graphics card). My friends and I couldn't figure out what was wrong, but we thought it might be the graphics card, so a buddy of mine brought his GPU over and switched it out.  still nothing.  We decided that the motherboard is probably bad, but i want to know what the forum thinks before i return anything. Also, another big problem is that the motherboard I'm using does not have an integrated graphics, so i cant even check BIOS or install windows, etc.  Please Help :)
build:
CPU: AMD - FX-9590 4.7GHz 8-Core OEM/Tray Processor
Motherboard: ASRock - 990FX Extreme6 ATX AM3+ Motherboard
Memory: Kingston - HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - GeForce GTX 1060 3GB 3GB SC GAMING Video Card
Power Supply: Rosewill - 550W 80+ Bronze Certified Semi-Modular ATX Power Supply
(did not include fan, sound card, wifi adapter, and case because i do not think there are relevant, i will post if they are.)
https://linustechtips.com/topic/815314-fresh-build-no-display/
Says "fresh new" I imagined Ryzen or Kaby Lake... then.... FX-9590! lmao.
If I had to guess from the top of my head what's wrong here I would say it's that 550w only for this monstrous power eating CPU.
AMD themselves say that you should have have at least a 850w PSU for a single GPU setup with it, the 1060 consumes it's power as well, not to mention the 7200rpm HDD which also consumes considerable power, fans PCI-e cards and all you mentioned to have in it... I honestly think we're looking for insufficient power here.
Terrible purchase also, who the hell wants a FX-9590 in 2017:
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/815314-fresh-build-no-display/#findComment-10227511
 I guess "fresh" wasnt the best word, but im still new to this. also i was on a budget and i dont know how to pick the best parts, but for now as long as it works, im ok with it.
anyway criticizing the build aside, you think that the power supply needs to stronger to support all the parts? i just wanna be clear cuz this is all still a little confusing.
https://linustechtips.com/topic/815314-fresh-build-no-display/#findComment-10227533
I checked out the power calculator, and it says recommended is at least 508w, so i should be good.  I am going to read that README to see if that helps now.
EDIT:  i've pretty much checked everything and nothing is working.  even though i think i have enough power, im hearing that i might need more.  can anyone share insight on if they think that is really the problem, or if its a motherboard issue?
https://linustechtips.com/topic/815314-fresh-build-no-display/#findComment-10227651
