My Build: https://uk.pcpartpicker.com/list/x86Tcc
I plan on overclocking my cpu but i dont want my build to be too loud.
Should I get an AIO liquid cooler?
If so which liquid cooler should I get?
CPU: Ryzen 3700X Motherboard: Gigabyte X570 Pro Wifi CPU Cooler: NZXT Kraken x62 Rev 2 RAM: 16GB Corsair Vengeance DDR4 3000Mhz GPU: Asus TUF OC RTX 3080 SSD: 250GB SK Hynix SATA and 2x 1TB Samsung 980 Pro M.2 PSU: Corsair SF750 Case: Cooler Master NR200 Monitor: LG 27GL850 Keyboard: Logitech G810 Orion Spectrum Mouse: Razer Viper Audio: Sennheiser PC37X and Logitech G560 Speakers
https://linustechtips.com/topic/814530-should-i-water-cool/
If you want cooling performance along with silence (or rather, less noise), you'd be better off going with a Noctua NH-D15 or bequiet! Dark Rock Pro 3. They perform around the same as a 240mm AIO but usually result is lower noise levels as well as having less to go wrong.
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10218915
Ok i will go with the dark rock pro 3 because i hate the noctua colours
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10218923
Just swap the fans on the D15. ez
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10218958
is the d15 much better than the dark rock?
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10218990
will the be quiet! pure wings 2 140mm fit the d15?
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10218999
Just now, Kenji the Uke said:
Its more of.. the dark rock pro SUUUUCKS to install. Noctuas mounting system is seriously freaking incredible
nice, im looking for ram that is small enough to fit under the damn thing
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10219024
The D15 does have cutouts for taller ram, though you should definitely still make sure it fits. In my experience, when you do the build, make sure the memory is in first. It might fit but its impossible to put in when the cooler is on =w=;; Just because of the angle..But thats the same with any cooler with that kind of hangover.
Moist
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10219030
i wouldnt mind spending extra to buy an aio and not have to worry about ram
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10219041
But then you'd have worry of pump failure and pump noise in addition to the fans :v I mean I definitely understand the AIO want. I might do it as a next cooler myself and pump failures are definitely a rarity. Just somethin to consider. Which AIO did you have in mind? I'd get a 240mm or larger and brand wise, you cant really go wrong between NZXT and corsair. Heck, even Fractal Design has a new 360mm AiO :v
Moist
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10219049
i was thinking 240mm and maybe corsair, nzxt, thermaltake and im not sure about others
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10219054
Update: Also :v for some reason fractal and nzxt have weird pricing/lacking pricing.
i like the nzxt kraken but im not sure if i want to pay an extra 30 for the front
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10219068
I swore it used to be like.. 129.99 :v what the fug Yeah. I would however, regardless of the model, look up their warranty. See if they cover damage caused by leaks or the such. Corsair's warranty tend to be really good but definitely look into it.
Moist
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10219084
I went with the kraken i cant resist that sexy front
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10219085
For CPU only, AIO makes sense.
Good choice on the Kraken, looks very sexy :>
If you were doing CPU + GPU then I would suggest the FluidGaming kit from EKWB and going more custom :)
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10219095
How much is it?
£130
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10219100
1 minute ago, Kenji the Uke said:
How much is it?
im looking into it tho because it still has a rly small ram clearance
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10219106
Owo Really? I didnt even know that was an issue with it. Weird. WATCH YOUTUBE VIDEOS
yeah i didnt even think they got close to the ram, oh i will trust me
https://linustechtips.com/topic/814530-should-i-water-cool/#findComment-10219117
