SOLVED: RAM not running anywhere near full speed
Solved by johndms,
8 minutes ago, greenlotad said:Okay, finally updated the bios. Nothing has changed though, it's still at the same frequency
I don't know what to tell you, then. It's a very simple process. Enter bios, enable XMP, select 3200 profile, save changes and reboot. You could always try entering things manually... perhaps 2666MHz, 18-18-18-36 at 1.35v just to see if it works. But if it's a 3200MHz kit, then it should have no problems if you're using the latest bios released three weeks ago, 7A37vA5.
