I was just writing a reply there to a topic which I had started, and was using a quote in order to quote myself for something I had said off site (long story read that thread if you wanna find out more, shouldn't be too hard to find) but anyways what I was quoting I just copied and pasted in, but due to what I was coping and pasting in having links in it, instead of pasting the entire thing it just pasted the top link. Which is obviously not what I wanted or needed, I have done what I needed to do now, but it was just a slight inconvenience that I couldn't just paste what I was saying directly in. I must quicky add, when I say quote I do not mean using the quote button below someones post, I mean the one on the bar which has the options for italicsbold, underline, etc.
Quote
this yen
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
https://linustechtips.com/topic/812067-small-bug-with-quotes/
1 minute ago, colonel_mortis said:
What browser do you use, including version? http://www.whatsmybrowser.org/
according to that website chrome 59.
https://linustechtips.com/topic/812067-small-bug-with-quotes/#findComment-10191905
21 minutes ago, colonel_mortis said:
I can't reproduce this in Chrome 59. Does it happen every time?
it was when I was writing that, and yes and no. If I use word etc. no, if I use the the windows 10 mail, if the message is long enough, yes, shorter messages no. I have just tested it using what I wrote for the thread and
"bla bla bla
www.linustechtips.com"
It only seams to occur when copy and pasting from win 10 mail to the reply (I have just tested it without the quote and it happens there too) from wordpad though it didn't occur, even with the same text. so it seams to be to a specific program, which might affect very few people, but still. I have no idea what the minimum size of the thing being copied and pastes needs to be, but the thing I was trying to copy and paste was 4750ish characters long, so it wasn't exactly short
https://linustechtips.com/topic/812067-small-bug-with-quotes/#findComment-10192015
