Help with python error
✪NaCl✪
Hello there,
For my python class i have to make a program with will ask for city and temp in fahrenheit convert it to celsius and display, But i keep getting a error and i dont know whats wrong.
Here's my code.
please help
>>> city=input("What city are you in?")
temp=int(input("What is the temprature?"))
nwtmp=int(temp-32)
if temp < 50:
  print("You are in",city,"The temprature is",nwtmp*5/9,"celsuis and it is winter")
elif temp < 65:
    print("You are in",city,"The temprature is",nwtmp*5/9,"celsuis and it is spring")
elif temp < 79:
    print("You are in",city,"The temprature is",nwtmp*5/9,"celsuis and it is fall")
elif temp > 80:
    print("You are in",city,"The temprature is",nwtmp*5/9,"celsuis and it is summer")
SyntaxError: multiple statements found while compiling a single statement
it would help to know where the error was found. what line.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
You're trying to copy/paste a script into an interactive shell. You need to go to File > New File, then put the code in there, save it, then run it.
1474412270.2748842
Also, put the nwtemp*5/9 in brackets with str in front like this:
str(nwtemp*5/9) as without it the print functions wont work because it doesn't allow integers only strings
You have to make a .py file and run it.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
The print function accepts numbers fine.
1474412270.2748842
ok then.
I started to write the code myself and it wouldn't let me do the nwtemp operation in the print statement
Thanks for correcting my mistake man :)
You need to use code tags:
I won't help you until do.
The single biggest problem in communication is the illusion that it has taken place.
Oh ok I got it working by saving it and running. Thanks.
It sometimes immedialty crashes when I try to run it. Any ideas why?
it doesnt show me a error the program just opens the immediatly closes
Would not it just give me a error instead of crashing it?
Ok so cmd prompt run type in program name? I
So say it was on my desktop and named w what would I type
C:\Users\Ray-Gaming\Desktop>python [d.py]
'python' is not recognized as an internal or external command,
operable program or batch file.
2 hours ago, ✪NaCl✪ said:
elif temp < 79:
elif temp > 80:
with this code if you input 79 it would not do anything. You should change the last one to else.
why do you set nwtmp and then do maths to it in the string? You should just do it when you set it.
printing will look much better if you do something like this
print("You are in {0}. The temperature is {1}".format(city, nwtmp*5/9))
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
Thanks for the info I just started today. But when I try and run the program it immediately crashes
