No post on new PC help
I built my PC about a month ago.I could not get it to post on power, so I figured it might be a motherboard issue.
A week later, a new motherboard I ordered arrives ( MSI B250M Pro-VDH) which has a debug LED. On power, still no post but the debug LED points at a CPU issue.
3 weeks go by and I get around to ordering an new processor (Intel core i3 7100 .....Literally the same one) and once it arrives, I quickly install it. No resolve whatsoever.
Pls help I have never built a PC before
make sure the 24 pin and cpu 4/8 pin are plugged in, the psu is plugged into the wall and the switch on the back of it is switched to I  If you have it wired to your case make sure the wires go to the right pins, if not make sure you're contacting the power pins with a flat head screwdriver
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Take the ram out and everything and test it with the Igpu (The video ports in the mobo (mobo=motherboard))
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
Kind of off the point, but why i3 7100 when cheaper Pentiums perform more or less the same?
Desktop benching:
People aren't that informed with stuff
can you please provide a picture of the mobo and everything you have installed on it. That would really help, otherwise, it's kind of like shooting in the dark hoping to hit something.
Honestly idk I just felt confident going for something that seemed newer at the time. I know, dumb reason but its too late now
17 minutes ago, Being Delirious said:
Try recentering it.
I don't understand
Just now, Godofkings17 said:
I don't understand
Take the cpu out and put it back in with the arrow facing to the arrow on the board.
The geek himself.
remove the graphics card and plug into the mobo outputs like Billy said
desktop
HTPC
Yes I made sure they are all plugged and even repluggled them. And that screwdriver method doesn't do anything...and I've been told that before when I had the first motherboard. Still nothing
The fans move for a split second but then don't move, the CPU fan shows no effect
Same thing, fans spin for a split second except for CPU fan
Still nothing
Is the RAM in the right slot for 1 DIMM?
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
Do you have a speaker (internal) and try with one stick of ram
yes, check the mobo manual make sure your memory is in the right slot. These boards like to run in dual channel, but it's not mandatory . If you have another compatible module try using both in dual channel mode. What power supply are you using?
Yes, well I tried the first and last slot for both sticks of ram
try the 2nd slot going from left to right that's labeled DIMMA2.
since you already replaced the mobo and cpu, the next most likely point of failure would be the ram. It's possible the stick is dead. Is that ddr3 or ddr4?
According to the manual "to boot up the system successfully, always insert the memory module into dimm1 first
Ddr4, its weird because my mobo debug LEDs point to it being a CPU issue
