I don't know about the P400, but I've built in both the NZXT S340 and the Phanteks Enthoo Luxe.  The NZXT is a nice design, although I personally got a bad unit that needed to be RMA'ed.  My Phanteks was an absolute joy to build in, partly because of the detailed documentation and included parts box, but also because of my stupid fat fingers.  Based on personal experience with the S340 and Phanteks brand experience, I think you'll be happy with either, although I think the Phanteks case will have better included fans and instructions, if that sways you any.  The S340's instructions are on the bare side in comparison, so you may be annoyed if you can't figure out something while building.
On 7/15/2017 at 11:54 PM, LeinadTM said:
May I direct your attention in the direction of the MasterBox 5?
I considered the Master Box 5 but I'm not sure if installing fans in the front would be a pain ._.
Edit: I mean the front panel is like glossy which is a finger print magnet T-T and nvm about the fan installation... It seems easy from a video I saw.
Hmm, I see.
On 7/15/2017 at 11:38 PM, TheExcaliber said:
White NZXT S340 Mid Tower or Phanteks - ECLIPSE P400 White Mid Tower or any other white cases around $45-$80?
Optical Drive IDC...
So mainly, I'm just seeking for a White case with Decent or Good Air Flow ..... I'm very descriptive ;-)
What are you looking to stuff inside the case?  Multiple drives?  Are you gonna watercool?  Full ATX or micro-ATX?
SFF-ish:  Ryzen 5 1600X, Asrock AB350M Pro4, 16GB Corsair LPX 3200, Sapphire R9 Fury Nitro -75mV, 512gb Plextor Nvme m.2, 512gb Sandisk SATA m.2, Cryorig H7, stuffed into an Inwin 301 with rgb front panel mod.  LG27UD58.
Aging Workhorse:  Phenom II X6 1090T Black (4GHz #Yolo), 16GB Corsair XMS 1333, RX 470 Red Devil 4gb (Sold for $330 to Cryptominers), HD6850 1gb, Hilariously overkill Asus Crosshair V, 240gb Sandisk SSD Plus, 4TB's worth of mechanical drives, and a bunch of water/glycol.  Coming soon:  Bykski CPU block, whatever cheap Polaris 10 GPU I can get once miners start unloading them.
MintyFreshMedia:  Thinkserver TS130 with i3-3220, 4gb ecc ram, 120GB Toshiba/OCZ SSD booting Linux Mint XFCE, 2TB Hitachi Ultrastar.  In Progress:  3D printed drive mounts, 4 2TB ultrastars in RAID 5.
May I ask, which case have better air intake or air flow, NZXT S340 or Phanteks - Eclipse P400?? (Sorry this is a late respond b/c I actually gotten lost in my thoughts xD)
Not sure.  From what I understand the P400 includes 2 fans and the S340 includes three.  The S340 has a large open space at the front (front side intake) with a dust filter that allows for relatively easy cleaning.  The P400 has space for additional fans at the front beyond the single included fan, and its primary intake is a big hole near the bottom of the front panel.
