Will build a gaming PC for my wife
I have these parts lying around
  • Corsair RM 750x
  • SSD's - m.2
  • HDD's
https://pcpartpicker.com/list/zLWQbj
any reviews about the motherboard?
I choose this board since its color neutral (pink/blue) build so no red accented boards
Is the Ryzen RAM compatibility solved?she wants an RGB RAM maybe change the RAMs with G.Skill Trident Z RGB
for the GPU still waiting for the pricing of mid level cards to normalize.
Ryzen  5 3600 | ASUS Strix B450i Strix | G-Skill Trident Z RGB 16gb 3200mhz
Gigabyte RTX 2070 Super OC | Samsung 970 EVO Plus 500gb | NZXT H200i | NZXT x52 | Corsair RM650x
https://linustechtips.com/topic/807488-ryzen-wife-build/
Seems good.
you don't need a 212 Evo. the stock cooler is good enough unless you're going for 4Ghz.
Yes, RAM compatibility is fixed, although still not as flawless as intel. you definitely can get your RAM running at 3Ghz pretty easily, although it still may take a few minutes of tinkering beyond just loading the XMP profile.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/807488-ryzen-wife-build/#findComment-10142653
trident z and corsair vengeance have a pretty good track record on ryzen, but I would throw another $20 at the mobo, personally don't like Asrock, but avoid MSI I've heard horror stories for ryzen E:extra $20 on mobo for quality, haven't heard much good from cheap b350 boards
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/807488-ryzen-wife-build/#findComment-10142664
I can't list the case in pcpartpicker, I only trust ASUS bios and quality (strix b350F), but they don't have mATX which will fit in Corsair Air 240.
Only if I will found another mATX board I'll replace the Asrock, but for now this is best option i have, it has 2 m.2 slots and a RGB header at a very cheap price.
https://linustechtips.com/topic/807488-ryzen-wife-build/#findComment-10142688
9 minutes ago, RadiatingLight said:
Seems good.
212 evo if I have a spare in the budget, but yes the stock cooler will do fine, no plans of pushing the clock speed at its limit.
https://linustechtips.com/topic/807488-ryzen-wife-build/#findComment-10142693
I have the ATX version of your micro-atx board.  My Build I updated the bios as soon as I had my OS installed and my ram kit runs just fine with XMP.  I run into a few blue screens when attempting to tighten the timings, or overclock the 3000 kit to 3200, but overall.. I'm satisfied with my Asrock board.
One thing I noticed.. the micro-atx version only allows you to control the case fan speeds of one header, CHA_FAN1.  CHA_FAN2 runs 100%.  For this reason, I chose the ATX version, which gives me one additional fan header, CHA_FAN3, since I like to control my six case fans with SpeedFan according to the temperature of my GPU.  Source
CPU: Ryzen 5 5600x  Board: Asus PRIME X570-P  Ram: G.Skill Ripjaws V Series 16GB (2x8) DDR4-3000  Case: Fractal Design Define S
GPU: NVIDIA GeForce RTX 3070  SSD: HP EX950 1 TB M.2-2280 NVME  HDD: Seagate Barracuda 3TB 3.5" 7200RPM
PSU: SeaSonic FOCUS Plus Platinum 750W  Cooler: Noctua NH-U12S SE-AM4  Monitor: Viotek GFT27DB 27.0" 2560x1440 144 Hz
https://linustechtips.com/topic/807488-ryzen-wife-build/#findComment-10142754
Thanks!i will use a fan hub with so it no issue for me,btw thanks for the heads up
https://linustechtips.com/topic/807488-ryzen-wife-build/#findComment-10144635
