Hey all, I've been slowly gathering parts for my first rig here and there and for the most part I've got everything sussed out, except for the case. I originally wanted to go with a nice clean white nzxt s340 elite but after listening to gamers nexus concerns in regards to thermals in comparison to something like the corsair 470x or 570x I'm less sure now. Do case thermals really impact anything that much overall? I dig the 470 and 570 as well but obviously they're at least a bit more expensive than the elite.
Current build
https://pcpartpicker.com/list/Jb7psJ
https://linustechtips.com/topic/806606-need-a-little-case-help/
Current build
i have the NZXT S340 ELITE in white and thermal wise, well, i have a custom loop, and i idle at around 30. and when on load i go up to about 60-70 centigrade.
Bow down to me humans.
I can't help if you don't quote me. How am I supposed to know if you need my premium support? Now starting at £399.99 a year.
Also, be a sport and mark the correct answer as the correct answer. It will help pour souls in the future when they are stuck and need guidance.
"If it works, proceed to take it apart and 'make it work better.' Then cry for help when it breaks." - Me, about five minutes ago when my train of thought wandered.
Remember kids, A janky solution is still a solution.
https://linustechtips.com/topic/806606-need-a-little-case-help/#findComment-10133216
In other words pretty damn warm haha, well thats good to know. Assuming I'm doing the conversion from celsius to fahrenheit properly.
https://linustechtips.com/topic/806606-need-a-little-case-help/#findComment-10133236
bear in mind, i do live in a hot country where advrage temps are about 40-50 degrees anyway
https://linustechtips.com/topic/806606-need-a-little-case-help/#findComment-10133267
Good to know, I do wish nzxt would have made room for two fans up top at least though, seems like a strange design decision.
https://linustechtips.com/topic/806606-need-a-little-case-help/#findComment-10133282
it is annoying, but i havent got a fan there anyway, it looks a bit out of place.
https://linustechtips.com/topic/806606-need-a-little-case-help/#findComment-10133548
You AVERAGE 40-50ºC??????
https://linustechtips.com/topic/806606-need-a-little-case-help/#findComment-10136573
i know. but it is very hot in my room anyway.... ill tell you when it catches fire :)
but i am working on it..... probs would help that pc hasnt been cleaned in three months.....
https://linustechtips.com/topic/806606-need-a-little-case-help/#findComment-10137215
The case I'd recommend would be the Cougar Panzer.
Thermal-wise, if they're running that hot, don't expect them to last as long overall unless they get plenty of breathing room. The case I'm suggesting has nice, big, open mesh panels that lets in lots of air for all of the components.
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
https://linustechtips.com/topic/806606-need-a-little-case-help/#findComment-10137223
I thought you meant air temperatures
https://linustechtips.com/topic/806606-need-a-little-case-help/#findComment-10137246
i did. but chances are my pc will catch fire. the list of bad things has grown large, quickly.....
https://linustechtips.com/topic/806606-need-a-little-case-help/#findComment-10137266
Well RIP you dude.
https://linustechtips.com/topic/806606-need-a-little-case-help/#findComment-10137269
1 minute ago, TVwazhere said:
Well RIP you dude.
ik
https://linustechtips.com/topic/806606-need-a-little-case-help/#findComment-10137275
