PC booting up too fast! HELP?
Solved by Corwin111,
2 hours ago, Vielo said:There are my power settings;
Allow Hybrid sleep: ON
Hibernate After: NEVER
Well there you go. What you are seeing is hybrid sleep, not a full shut down. It turns off all the fans and drives and retains your session in RAM after writing a copy of it on the drive in case of power loss.
It's perfectly ok to use it like that and seeing as you have a HDD, probably preferable to full shut down.
