So before I start, I can't get a NZXT HUE. Anyways, I was wondering what would be the best for aestheticvs. Red LEDs in a Artic White C70 with red/black themed MOBO and cables or White LEDs in a Artic White C70 with red/black themed MOBO and cables? All I could find is pictures of it with RED LEDs and it looked not bad, but I would really like to know how it would look with white LEDs. Would it be to much white since the case is white? What do you recommend?
https://linustechtips.com/topic/80372-leds-best-color/
I would personally say B
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/80372-leds-best-color/#findComment-1101847
Red LEDs. Give more of the red accent to it.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/80372-leds-best-color/#findComment-1101851
I'd say go red mobo and cables with red led. Do not get led fans though, that will over do it.
Intel i5 4670K 3.4GHz | EVGA 780Ti Classified | ASUS Gryphon Z87 w/ Armor Kit | G.Skill Sniper 8GB @1866MHz
Samsung 840 Evo 500GB | Seagate Barracuda 3TB | Kingwin Lazer 850W Bronze PSU | Corsair 350D Window
Razer Blackwidow Ultimate BF3 Edition | Razer Naga Molten
https://linustechtips.com/topic/80372-leds-best-color/#findComment-1101852
White. Colors are tacky imo. i dont want my PC to look like a christmas tree i want it to be illuminated and i want it to look like im looking in through a window into a sexy pc.
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/80372-leds-best-color/#findComment-1101875
Okay. What LEDs would you recommend? Icemodz?
Icemodz, NZXT HUE, NZXT Sleeved kit LEDs, Bitfenix Alchemies
https://linustechtips.com/topic/80372-leds-best-color/#findComment-1101876
only have had experience with bitfenix alchemy strips, and they look great
https://linustechtips.com/topic/80372-leds-best-color/#findComment-1101900
Either would look fine imo, provided you don't go overboard if you do go with red. Avoid NZXT sleeved kits, from my experience they provide uneven lighting even with doubling up on the cable. I personally went with a custom LED system, but any medium or high density LED strip will suffice. That being said, look at Phobya strips, Bitfenix Alchemy strips, or something from Icemodz.
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
https://linustechtips.com/topic/80372-leds-best-color/#findComment-1101924
If you want to show off your parts, go white. If you want to drown everything in red and make all of your components look red, get red.
i5 4670k | Sapphire 7950 | Kingston 120GB SSD | Seagate 1TB | G.Skill Ripjaw X Series 8GB
PB238Q | Steelseries Sensei | Ducky DK9087 | Qck Heavy
Build Log: http://linustechtips.com/main/topic/44902-from-imac-to-my-own-creation/
https://linustechtips.com/topic/80372-leds-best-color/#findComment-1102776
