Help with choosing monitor
Huber
Hello guys. Im playing Call of Duty on the Xbox One and I´m looking for a new monitor. But I have no idea of which one I should buy. My budget is about 140-150£. The only thing that the monitor needs is built-in speakers. I will use a headset while playing. But me and my mates often watch movies together so it's unfortunately a must. If you guys could help me I would really appreciate it. Thanks in advance :)
Do you mean TV?
find a 720/1080p tv for cheap (used is an option)
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
@themctipers
Do you get the same quality in a Tv as in a monitor? For about the same price
37 minutes ago, Huber said:
@themctipers
Monitor has better response and possibly better panel colours than TV for the same price
but you won't notice it because an Xbox is tuned for a TV in mind, you don't plug in a console to a dedicated monitor
But if I buy a monitor, will it be no difference on the Xbox from playing on a TV? I will also play some games on my computer so it would be nice to have a screen that I can use to both.
Im thinking im going to go with the Asus VE248HR 24"
 https://www.amazon.co.uk/dp/B014RKR8K8/ref=s9_acsd_bw_wf_s_GAME_cdl_26?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=merchandised-search-10&pf_rd_r=EK3J5VGZ7D0BCNV86N9V&pf_rd_t=101&pf_rd_p=1885017c-3f00-461a-9a9f-a8d4f99d084f&pf_rd_i=9320946031
Do you guys think it will be good. And if someone has one, would you recomend it?
Iv made my decison.
