What are your temps?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/803642-fan-speed/#findComment-10101953
3 minutes ago, Dreaper said:
What should i set my fans at for performance?
Maximum.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/803642-fan-speed/#findComment-10101956
Need a lot more info to give a proper suggestion.
-Full system specs?
-Case?
-Case fans (how many, what size, what position (front, bottom, rear, top// intake, exhaust?))
-What are you currently using to control them?
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
https://linustechtips.com/topic/803642-fan-speed/#findComment-10101967
16 minutes ago, Dreaper said:
BIG EDIT MY FANS ARE FREAKING OUT MY H100I fans keep ramping up then down over and over please help
I thought you wanted performance...
in corsair link, set the temp curve to H100i Temp, not CPU temp. CPU temp is irrelevant. You are cooling water, not the die.
System specs:
https://linustechtips.com/topic/803642-fan-speed/#findComment-10102024
1 minute ago, Dreaper said:
It won't let me change anything in corsair link
how familiar are you with the program?
System specs:
https://linustechtips.com/topic/803642-fan-speed/#findComment-10106840
17 minutes ago, Dreaper said:
never used it
you can click on the fan speed icon in the h100i box to bring up the fan curve, presets, and temp source. make sure h100i is selected for temp. if need be i can demonstrate later tonight.
System specs:
https://linustechtips.com/topic/803642-fan-speed/#findComment-10107451
never used it
Is pump USB connected to board and fans to pump? Otherwise you need to use mobo's software, or Speedfan.
As for curve, thats very personal thing. Usually you find the high point by testing at which rpm you get annoyed by fans and use that only when really needed. Rest of the time they should be running either as low as possible, or hanging somewhere in between. I use mainly straight line, stepped for GPU and 3pins. Some use more logarithmic to get faster speeds when CPU/GPU really heats up.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/803642-fan-speed/#findComment-10107533
fans are connected to mobo and pump is connected via usb to pump
https://linustechtips.com/topic/803642-fan-speed/#findComment-10107543
You mean pump is also connected to mobo and usb to mobo? Because otherwise your pump doesn't do anything. Link can only control pump and fans connected to pump.
https://linustechtips.com/topic/803642-fan-speed/#findComment-10107557
pump is connected to the mobo via the usb slot on the mobo, and the fans are in the CPU1 and CPU2 fan  slots
https://linustechtips.com/topic/803642-fan-speed/#findComment-10107561
why are you not using the fan headers from pump?
wait, WHICH h100i is this? specifically... the V2?
System specs:
https://linustechtips.com/topic/803642-fan-speed/#findComment-10107564
No its not the V2 and its not connected to the fan headers on the pump because the fans went bat shit crazy with it on that
stock fans or aftermarket? and again, probably went bat shit because it wasn't configured to the water temp. had the same issue with my h115i. thought it was just the shitty controller software and dropped $50 worth of fans to at least quiet it down. then i found the settings.
System specs:
https://linustechtips.com/topic/803642-fan-speed/#findComment-10107598
Please tell me pump is getting power. I don't use AIOs, but quick look on manual tells that it should get main power from SATA and only use mobo for controlling pump.
https://linustechtips.com/topic/803642-fan-speed/#findComment-10107637
Stock fans i have some extra Venturi HF-14 if you think that will be better
https://linustechtips.com/topic/803642-fan-speed/#findComment-10107653
Just now, Dreaper said:
pump is getting power yes yes yes
For a second I thought that was the issue here. Anyway, since fans aren't connected to pump, you can't control them with Link. You need to use mobo software/BIOS for it. And if you have pretty much anything else than Gigabyte, that should be breeze.
https://linustechtips.com/topic/803642-fan-speed/#findComment-10107664
