Hi,
as the topic states, I'm currently on the hunt for a laptop which I will be using primarily for work (e-mails, web browsing, documents) therefore I don't need a lot of performance or storage. What I do want however is a solid battery life. I don't know much about laptops so I'm currently trying to narrow down on a manufacturer and model series. Dell's Latitude series is on my radar right now, but honestly it's mostly due to the fact that it's the only business laptop series I know of, so I'm looking for alternatives for comparison.
I'm also wondering if perhaps I should wait for the release of Zen core based APUs. Do you think I might save much by doing this? Also does anyone have any idea how long  AMD will take until they release their full lineup?
https://linustechtips.com/topic/803031-looking-for-a-laptop-for-work/
Well for that kind of use case you might consider the MacBook:
https://www.apple.com/shop/buy-mac/macbook?product=MNYF2LL/A&step=config#
If you think you will need USB ports or HDMI ports you can get this as well:
https://www.amazon.com/Satechi-Aluminum-Multi-Port-Charging-Chromebook/dp/B01J4BO0X8/ref=sr_1_5?ie=UTF8&qid=1499359945&sr=8-5&keywords=USB+C+dock
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
10 hours ago, lilbman said:
Macbook Air.
Nah, the only people who should get MacBook Airs are old people Imo who just need a computer because they need a computer lol.
You should get a t460s last gen
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
