Title pretty much says it. For a boot drive running OS/apps which is the more important factor, talking about a mechanical drive here by the way. I've always gone with IOPS for boot and seq for data drives but hey I could be wrong. Enlighten me!
pc specs: 4 function calculator / 8 digit lcd display / colored numeric and function buttons
https://linustechtips.com/topic/801496-sequential-v-iops-for-general-use/
Depends what apps.
Stuff like video editing will require a ton more sequential.
Just now, Enderman said:
Depends what apps.
What if we're talking pretty much just OS, web browser and some basic games
Then 4k speeds are more realistic.
But with an SSD it is already not a bottleneck, so paying more for faster speeds will literally make 0 improvement.
For example a NVME SSD which has multiple times better sequential and 4k speeds than a sata SSD, but still gets no improvement in boot time or program launch times.
Do you mean sequential vs randoms?
IOPs stands for Inputs Outpus Per second, and is a measurement of performance just like MB/s. Sequential performance can be measured in IOPs.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
Unless it's one that's got like 10-20MB/s read speeds.  You'll notice a difference at boot up.  If you open up Resource Manager right away it will be at 100% usage.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
Sorry yes. I'm using CrystalDisk so Sequential MB/s vs 4K IOPS.
One thing that I haven't seen mentioned, and I would really like to know, is...
When you run out of RAM (& can't install more because your motherboard is maxed out), and have to use on-disk swap,
What is more important to lessen the "slow to a crawl" effect that you get on a spinning-platter HDD when swapping?  Sequential, or 4K/random?  I'm primarily talking about SSDs here.  (Also, what about SATA vs NVMe in that scenario, & how much difference vs platters...)
I'm guessing 4K/random IOPS is more important when linux swap / windows pagefile is involved.  Is that right?
There is no difference between a sata 3 SSD and an NVME SSD for boot or launching programs or anything like that.
There is only a difference when doing stuff like video editing, data analysis, etc.
I can tell you from personal experience with a ton of different SSD models, there is a noticeable difference.  I've even tested it with cloned drives.  An NVMe drive can have slower boot performance compared to a SATA drive, but it's rare.  Usually the random read speeds are faster on NVMe drives.
At a certain point the drive is fast enough that it doesn't max out during boot and you don't see a difference.
Nope, that's called a placebo effect.
There is no difference and there are literally dozens of benchmarks on the internet that prove that.
Storage speed is not a bottleneck of boot time.
I guess I totally imagined timing different drives. 9_9
And here:
And here:
Oh well if you're talking about the intel 750 then sure, everyone knows that one's pretty slow.
I mean like equivalent drives, from the same brand, like an 850 vs 950.
All are within margin of error.
Image result for nvme boot time
Those have fast 4K read speeds.  No Samsung drive is going to max out at boot.  They're top of the line.  I would count those differences as within the margin of error.  When you start getting to the budget TLC ones (especially the brands nobody has ever heard of), you start seeing a difference.  Now granted, it's not huge.  You'll save probably save 5 seconds at most by getting a high end drive over a crappy one.  I would never tell someone to get an NVMe drive for a boot drive, unless there was some crazy sale.
My laptop came with a relatively slow SSD (18MB/s on the 4K reads), and replacing it yielded better performance.
PS: You should read the poorly translated description on the drive I linked. "we will do replacement or refundxD
