Questions on an AiO
Go to solution Solved by DoctorZeus,
5 minutes ago, martward said:
Hi all,
I have just gotten an AiO from a friend (CoolerMaster seidon 240V) which he had laying around and I wanted to test it this weekend. I have a couple of questions though.
1) I have two fans and the cpu block that I need to connect. I have two CPU fan headers and three sys fan headers on my motherboard, what should I connect to which header?
2) I want to test for leakages outside the case before actually installing it. Can I just connect everything to the motherboard while my air cooler is still installed (and connected to one of the CPU fan headers) to see whether it leaks?
1) Pump to CPU Header Always. Fans irrelevant.
2) Yes as long as you connect the pump you can run it like that
Hi all,
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/800044-questions-on-an-aio/
Hi all,
https://linustechtips.com/topic/800044-questions-on-an-aio/#findComment-10063670
Just make sure you still have something cooling the cpu when you turn the pc on...
https://linustechtips.com/topic/800044-questions-on-an-aio/#findComment-10063686
Yeah I was going to just keep my current cooler in until I am sure that it's not leaking. It was moved in a plastic bag since the box had already been thrown out ^^.
My System:
https://linustechtips.com/topic/800044-questions-on-an-aio/#findComment-10063693
So Cpu block on CPU fan 1, one fan on CPU fan 2 and one fan on SYS fan 3 would work?
Sys fan 1 and 2 are lower on my motherboard and I would like to prevent cables across the motherboard for aesthetic reasons.
My System:
https://linustechtips.com/topic/800044-questions-on-an-aio/#findComment-10063713
yeah that's fine. cpu fan 2 will run with your cpu temperature and sys fan 3 will need to be set by you for optimal results
https://linustechtips.com/topic/800044-questions-on-an-aio/#findComment-10065249
