I started downloading Payday 2 10 minutes ago or so, then (at about 20% of the process) it stopped downloading data. Steam download page says that hard drive is being used, but no thin is being downloaded. I have full conection to the internet, and I can't find any steam restrictions for downloading it. Anyone knows what to do?
I've already restarted the app three times and the computer once
Any help is truly appreciated
Thank you
https://linustechtips.com/topic/799275-i-need-help-with-steam/
3 minutes ago, KuJoe said:
How much space is left on the drive? I think Steam has a setting that if the drive gets above X amount full it stops all downloads.
Nevermind, it started back again just 30 secs ago for no reason, I'm freaking out a bit, but as soon as it works, I'm good with it. Thanks for replying
https://linustechtips.com/topic/799275-i-need-help-with-steam/#findComment-10055152
This is a common problem with Payday 2. My friends and I have nicknamed it the hard drive killer. A 500MB update can take hours. Payday has terrible optimization in regards to installations, and its something you can expect from it. Steam stops downloading because it needs to let your PC actually write stuff down on the drive, which takes forever for no real reason at all.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/799275-i-need-help-with-steam/#findComment-10057556
  • 3 weeks later...
Good to know, thank you
https://linustechtips.com/topic/799275-i-need-help-with-steam/#findComment-10164890
sounds like steam needs to down to 3 ram spaces get reserved(say 128mbyte each) then it can fill 1 space which on full writes to disk while switching to next ram space for continued download
https://linustechtips.com/topic/799275-i-need-help-with-steam/#findComment-10165111
