Hi, I would like to build a gaming PC and this build is based on Linus Tech Tips' Holiday Buyer's Guide 2016, the $1000 Build. Though, I stepped down the CPU and GPU for I do have a slightly tight budget but wanted to upgrade in the future.
CPU: Intel i3-6100 (3.7GHz)
GPU: Zotac Geforce GTX 1050
Motherboard: ASUS B150M Pro Gaming LGA1151 Micro - ATX
RAM: 2x Kingston HyperX Fury 8GB DDR4 2133MHZ
SSD: Samsung 250GB 850 EVO (for OS)
HDD: WD Blue 1TB
Power Supply: Cooler Master Thunder 500W 80+ (I just looked for the same rating and dimensions as the one listed on the 1000$ Build since it is not available on our local shop.)
Case: Thermaltake Versa H25
Total: almost $600. I only converted our currency to USD
I'm not particular with 1080p or 4k resolution I just wanted to play Witcher 3, Dishonored, Metal Gear Solid V in particular smoothly. I noticed that the $1000 Build had LGA1150 but the LGA1151 is the only available in our market. is it just fine? Thank you.
https://linustechtips.com/topic/799245-first-pc-build/
Buying from retail store?
Desktop benching:
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054771
use part picker please next time please it's so much easier to look at, and what's the budget, in your currency???
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054787
@xeto You can cut costs a little more by taking out one stick of RAM, as 8 GB is still quite adequate for gaming and regular usage. :)
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054804
8 minutes ago, xeto said:
sorry for that, I'm not that familiar with part picker. For the budget it's 800$ Max.
please quote when you reply so we know you have. As for that ok I will look at making you a quick list on part picker for you then.
@Freezanator @Jurrunio the OP has replied to you two.
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054833
Noted. :D my bad, again. thank you so much! :D
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054838
I know, because I turn notifications on and I refresh quite often. :)
My Daily Driver:
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054850
1 minute ago, xeto said:
with the G4560, do i have to do overclocking? what I am looking for is base performance without doing much.
No it is not designed for overclocking. The Pentium is not that far off the i3 in terms of performance, but it is usually around half the price.
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054856
That CPU can not overclock, if you want to overclock get G3528
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054870
ok made you a list, sorry it took so long, I am on shitty internet at the moment (.5Mbps if I'm lucky) so the PSU tier list took ages to load, but here you go, it's $15 dollars over the $800 you asked for, but that I would imagine is acceptable,
https://pcpartpicker.com/list/2cTZm8
the stock CPU cooler will do for a basic overclock and is not actually a bad cooler, but you might want a better one later on down the road for a better overclock.
6 minutes ago, lee32uk said:
Go with the G4560 rather than the i3 if you can source one, and a B250 board.
I would say go with an R5 1500X,
with pentiums and i3s no, witgh R5 yes
fair enough I wasn't sure as was just checking
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054872
or get a R5 1500X, which is possible with a $800 budget,
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054874
Isn't it better to get a r5 1400?
Desktop benching:
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054898
no the 1500X has more cache than the 1400, so gettiing the higher cache of the 1500X is a good idea,
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054905
Just now, lee32uk said:
That is going to be a lot more than the Pentium though.
true, but the op with a $800 budget can afford it, as well as getting a 1060 6GB (can't get 580 due to them being out of stock) which will be a good PC which can game as well as do other stuff as well
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054912
I guess i already make that list, wait
My head on 2019 :
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054920
waiting waiting waiting... :P
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054925
Sorry sorry sorry
$800 ish
[PCPartPicker part list](https://pcpartpicker.com/list/JFgr8K) / [Price breakdown by merchant](https://pcpartpicker.com/list/JFgr8K/by_merchant/)
Type|Item|Price
**CPU** | [AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor](https://pcpartpicker.com/product/VtFXsY/amd-ryzen-5-1500x-35ghz-quad-core-processor-yd150xbbaebox) | $176.99 @ SuperBiiz
**Motherboard** | [ASRock - AB350 Pro4 ATX AM4 Motherboard](https://pcpartpicker.com/product/yBtWGX/asrock-ab350-pro4-atx-am4-motherboard-ab350-pro4) | $87.99 @ SuperBiiz
**Memory** | [Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory](https://pcpartpicker.com/product/p6RFf7/corsair-memory-cmk16gx4m2b3200c16) | $135.88 @ OutletPC
**Storage** | [Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive](https://pcpartpicker.com/product/44Gj4D/seagate-barracuda-1tb-35-7200rpm-internal-hard-drive-st1000dm010) | $42.49 @ Amazon
**Video Card** | [Asus - Radeon RX 580 8GB ROG STRIX Video Card](https://pcpartpicker.com/product/9ZmxFT/asus-radeon-rx-580-8gb-rog-strix-video-card-rog-strix-rx580-o8g-gaming) | $280.98 @ Directron
**Case** | [Fractal Design - Focus G (Black) ATX Mid Tower Case](https://pcpartpicker.com/product/ZHmxFT/fractal-design-focus-g-black-atx-mid-tower-case-fd-ca-focus-bk-w) | $49.99 @ NCIX US
**Power Supply** | [SeaSonic - 650W 80+ Gold Certified Semi-Modular ATX Power Supply](https://pcpartpicker.com/product/R7V48d/seasonic-power-supply-ssr650rm) | $67.89 @ Newegg
 | *Prices include shipping, taxes, rebates, and discounts* |
 | Total (before mail-in rebates) | $862.21
 | Mail-in rebates | -$20.00
 | **Total** | **$842.21**
 | Generated by [PCPartPicker](http://pcpartpicker.com) 2017-06-27 04:48 EDT-0400 |
My head on 2019 :
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054953
wow. thanks a lot I would consider this build but  I think I would have a hard time finding the parts listed. any idea what online shops deliver to Philippines? I would appreciate a lot if there are any. Thank you :D
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054958
Sorry sorry sorry
$800 ish
Type|Item|Price
do you have a part picker link to that as looking at that is hard, Also good luck in finding a 580 they are nearly impossible to find, thus the 1060 6GB in my list
https://linustechtips.com/topic/799245-first-pc-build/#findComment-10054963
