So right now in this potato i have a PSU called RASURBO EAP 550 and this is the voltage that i get in Aida64. Was thinking to upgrade the PSU since in the future wanna upgrade to a I5-5700 and dunno if this potato will be enough for it. When i went to the local computer store the guy told me why do you need such an expensive powersupply... you can these noname ones for far cheaper. Are those worth it or do i really need the certified ones?
https://linustechtips.com/topic/798524-psu-advice/
Your PSU is a no-name and should be replaced. That said, AIDA64 is not an accurate software to read voltages with and you should ignore it completely.
https://linustechtips.com/topic/798524-psu-advice/#findComment-10046986
That guy is full of shit don't listen to him.
Psu quality definitely matters. If you have bad voltage regulation (which is evidently the case with the psu right now because regulation on the 3.3v rail is like SEVEN WHOLE PERCENT) or lots of voltage ripple you might see other components in your pc die quicker. As well, bad PSUs probably use bad components that would result in the psu also dying faster.
80+ certification doesn't mean better quality though generally higher efficiency indicates a higher quality psu. Not always though.
What PSUs are available for you?
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/798524-psu-advice/#findComment-10046994
 Okay... and what would you recommend? I mean the MB is a Micro-ATX with one single GTX1050ti. 450 or 550W?
https://linustechtips.com/topic/798524-psu-advice/#findComment-10046995
Well i suspected this since i got this power supply from the same store a while back when i had a GTX 550ti and that card died in like 1 year with a pink screen(most likely RAM fail). From what i've read so far i dont need really that many watts... i got a CPU/MB/RAM/GTX1050ti/2SATA drives and my budget for this will be most likely around 100Euro
https://linustechtips.com/topic/798524-psu-advice/#findComment-10047013
Yeah... watts isn't what you need. It's quality that you need.
450 or 550 would be fine for you. 550 if you think you'll ever go high end in the future.
What country are you in.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/798524-psu-advice/#findComment-10047064
1 minute ago, Dethanu said:
Romania
Any online retailers I could use to find a psu?
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/798524-psu-advice/#findComment-10047077
There are some like emag and pcgarage that are the biggest
http://www.pcgarage.ro/surse/seasonic/s12ii-520-bronze-520w/
Here's a good choice for you.
https://linustechtips.com/topic/798524-psu-advice/#findComment-10047102
Just now, Dethanu said:
That's a good price for a PSU but in the back of my head i have this fear if it's cheap  it's not that good "quality" :ph34r:
The psu naturally isn't the highest quality but it's quite a decent unit especially for the price. At the very least it'll be hugely better than what you have now.
If you want you could check out the forum psu tier list. This psu is a tier 3 there, which basically means "good for low to moderate budget builds"
Your current psu would probably be like tier 7.5. Aka crap and you might want to pray it doesn't blow up :P
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/798524-psu-advice/#findComment-10047124
It's a hell of a lot better than your PSU now, I'll say that much.
It's a Seasonic unit man. That's hard to beat for quality.
https://linustechtips.com/topic/798524-psu-advice/#findComment-10047128
Touche....No comment on this one o.O:P
Was reading the comments that the MB cable is really short and i'm planning to upgrade the case in the near future.
https://linustechtips.com/topic/798524-psu-advice/#findComment-10047129
SeaSonic G series is tier 2 on the list and good psu
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/798524-psu-advice/#findComment-10047156
It is tier three if i am correct? But what about Corsair HX or RMx?
My head on 2019 :
https://linustechtips.com/topic/798524-psu-advice/#findComment-10047180
If you want a few other options there are these that are a bit higher quality then the Seasonic @STRMfrmXMN mentioned. Naturally they cost a bit more.
http://www.pcgarage.ro/surse/corsair/cx450-80-plus-bronze-450w/
http://www.pcgarage.ro/surse/corsair/cx550-80-plus-bronze-550w/
These are better than the Seasonic but not by THAT much. They cost a bit more.
If you want a pretty high quality unit there's this guy.
http://www.pcgarage.ro/surse/corsair/tx550m-80-plus-gold-550w/
It also costs more though.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/798524-psu-advice/#findComment-10047419
