High Quality display port cables?
Solved by NoRomanBatmansAllowed,
Just now, theminnesotanman said:so basically it doesnt matter the cable?
Basically, as long as it's up to the current revision (e.g. DP 1.4), and the build quality is decent enough that it doesn't break the moment you touch it, it'll work pretty much flawlessly.
Featured Topics
maka0 ·
Posted in Storage Devices2 -
3
Ivan M. ·
Posted in Storage Devices3 -
AlDowy ·
Posted in New Builds and Planning1 -
Xrniu ·
Posted in New Builds and Planning2 -
8
3
