Hello, I have changed my mind again and this time I am thinking of making something custom. So I will be making my own custom compact mini ITX case. I am not finished making it but I have finished the layout so I can start picking out components. Here is what I have come up with:
PCPartPicker part list: https://pcpartpicker.com/list/yn9Tf8
Price breakdown by merchant: https://pcpartpicker.com/list/yn9Tf8/by_merchant/
CPU: Intel - Core i7-7700T 2.9GHz Quad-Core OEM/Tray Processor  ($315.00 @ Amazon)
CPU Cooler: Noctua - NH-L9i 33.8 CFM CPU Cooler  ($39.15 @ Newegg)
Motherboard: MSI - H110I PRO AC Mini ITX LGA1151 Motherboard  ($79.99 @ SuperBiiz)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($126.99 @ Amazon)
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive  ($219.99 @ Amazon)
Video Card: Gigabyte - GeForce GTX 1070 8GB Mini ITX OC Video Card  ($454.98 @ Newegg)
Other: HDPlex 400w HiFi DC ($88.00)
Other: Dell 330w 19.5V AC Adaptor ($160.00)
Total: $1484.10
Here is my rational:
CPU -  I need the lowest TDP while having good performance so the 7700t seemed like the obvious choice.
CPU Cooler - The L9i is the best compact cooler afaik and I should be able to run the fan fairly slow to keep noise down, if there is something smaller but just as good then please let me know!
Motherboard: I chose the cheapest compatible motherboard with an m.2 slot so I picked. I do have a skylake chip to flash a newer bios with so don't worry about that.
Memory - Corsair LPX ram just seems to be some of the best so I chose that. However I do have some Adata 2400 ddr4 ram so if I can get that to fit in my case, I will do that.
Storage - I didn't want to waste space with a 2.5" drive so m.2 is the way to go. There are cheaper 500gb m.2 drives but I don't know how reliable they are.
Video Card - The Gigabyte 1070 mini is the only card that will fit in a tight space. If you know of anything that is better and just as small then please let me know.
PSU - ATX and SFX power supplies are too big for my project so in a previous thread I decided on going with that combination of a HDPlex 400w power distributor and a Dell 330w power adaptor to cover power for my system.
If you have any suggestions or advice, I would be glad to hear it so tell me all your thoughts on this build. I understand that it is probably hard to recommend me stuff without a clear understanding of my case but I don't have anything I can show you right now. Thanks!
https://linustechtips.com/topic/797572-mini-itx-components/
NVMe is unnecessary if it's for a boot drive and apps, as it doesn't improve the times for them. If you want an m.2 drive for space reasons you could just check out drives like the 850 evo m.2
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/797572-mini-itx-components/#findComment-10037910
Good to know! Is the Intel 600p series good? Or would the 960 evo be the cheapest alternative:
https://pcpartpicker.com/products/internal-hard-drive/overall-list/#f=122080&S=500000,10000000&sort=price&page=1
https://linustechtips.com/topic/797572-mini-itx-components/#findComment-10037924
You might need some active cooling on the power brick as you can exceed that 330W brick rating when the 1070 goes under load. Also, have a look around to a thin-mini ITX board. If you're going custom case, you may as well get a thinner motherboard and then use a riser to get the PCIe slot where ever you need it.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/797572-mini-itx-components/#findComment-10037930
600p is meh, it performs like an 850 evo even though it's NVMe so if you can get it for same or cheaper than an 850 evo then sure but if it's more then not worth it.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/797572-mini-itx-components/#findComment-10037937
The GPU has a TDP of 150w and the system has a total tdp of 249w in pcpartpicker. So I don't think I'll be going over the 330w of the power brick, right?
I have designed the layout around the dimensions of that motherboard so I think I'll be fine but I'm still interested in one with a thinner one especially with the io. I'll look through PcPartPicker and see what I can find.
https://linustechtips.com/topic/797572-mini-itx-components/#findComment-10037988
TDP isn't power draw. It's a measure of the heat produced by the chip under load, though on average it's usually wrong. However, after having a little search on 1070 power draw figures, the system should draw about 260-270W in total, so yeah I guess it's fine :P
USEFUL LINKS:
https://linustechtips.com/topic/797572-mini-itx-components/#findComment-10038009
the 600p is the cheapest 500+gb m.2 on the list so I'll get that
https://linustechtips.com/topic/797572-mini-itx-components/#findComment-10038036
thanks for explaining that. If I notice it starting to fail I can probably position some sort of small fan to keep it cool.
https://linustechtips.com/topic/797572-mini-itx-components/#findComment-10038048
For CPU cooler, Cryorig C7 is the only good alternate. It's 10mm taller though. It's hard to beat 37mm tall
https://linustechtips.com/topic/797572-mini-itx-components/#findComment-10038158
I was looking at the c7 first but then I remembered Noctua also had a good low profile cooler too. 10mm is such a big difference so I completely ditched the c7.
https://linustechtips.com/topic/797572-mini-itx-components/#findComment-10038187
