I was wondering of the pros and cons of overclocking RAM past it's advertised speed. Is it dangerous/ bad for the modules? Is there any performance improvement? I have G.Skill 2x4GB DDR4 2133MHz CL15 RAM [NOT XMP ABLE MEMORY], but I have overclocked it to 2666MHz and CL16 within the last hour. Everything seems stable; I ran some CPU benchmarks like Cinebench and also PassMark ram tests and no problems. The synthetic benchmarks showed roughly a 35% performance increase. I have an i5-6600K @4.6GHz and a Asus Z170-AR Mobo.
First image is recommended speeds.594c99f282ba8_RAMSPD23_06_17.PNG.12d1d872d3a68a1d3e1f8cfdcd566e09.PNGSecond image is what it's running at now.594c9c41a1c17_RAMSPEEDS23_06_17.PNG.cd6ba1aac7c4e1fa0f235c336ce95939.PNG
https://linustechtips.com/topic/797389-overclocking-ram-past-rated-speed/
with Intel there's not much real world improvement, probably 10% from base speeds to the highest on market except in synthetic tests which don't matter. Ryzen has much bigger performance dependence on ram speeds and sees double digit percentage gains in real world usage going from base to higher speeds
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
But is it harming my computer by running at this speed?
no, ram can be difficult to get an OC stable, and it can surprise you at the worst of times, my point was there's very little reason to do it on Intel, but it won't harm your system (unless you raise the voltage on the ram which could fry it, though some people have run their ram at 1.9v for long periods of time *not a recommendation, bad idea imo*)
desktop
HTPC
The voltages are at stock, 1.2v and I wouldn't go above 1.35 for RAM as that's what factory overclocked ram runs at.
