Ok i need to delete CCleaner because it would'nt let me play csgo and i dont even use it. I've tried deleting it every way i know i tried control panel, the files explorer, found it in apps and feature and try to delete it it doesn't work and everything i try to delete it thought file explore it says it cant be delete because CClear is open. Can someone help
https://linustechtips.com/topic/796904-help-me-delete-cclearer/
You can't just type ccleaner into the search bar and open it and exclude steam in the options tab?
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
https://linustechtips.com/topic/796904-help-me-delete-cclearer/#findComment-10030542
You need to disable the system monitoring n the options. open CCleaner then click on Options then monitoring then uncheck the Enable system monitoring then do a system restart then uninstall it via the control panel. This could be the reason why it wouldn't let you run CSGO but anyway give it a try.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/796904-help-me-delete-cclearer/#findComment-10030550
I have monitoring on and csgo has always worked fine for me personally.
https://linustechtips.com/topic/796904-help-me-delete-cclearer/#findComment-10030572
