cpu: 5930k
mobo: x99 asus deluxe
I know when you re manually Overclocking the voltage lock too your set value to stay stable but is there any way to re enable undervoltage when the pc is at idle? no point of running 1.3V when cpu idle at 1.5ghz, waste of energy
https://linustechtips.com/topic/796145-idle-voltage-when-overlcocking-x99/
It doesn't really matter, it is not using more power when the CPU is not doing anything.
Anyway, it should still drop even if you use manual voltage as long as the C-states and EIST in BIOS are enabled.
If CPU-Z shows only the maximum voltage, check sensors in Aida64.
For me, CPU-Z always just shows maximum voltage if I am using manual. Aida64 shows it correctly.
Adaptive should drop it down.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
