Have your PSU plugged in to the wall but switched off while building and touch it every once in a while or before you handle vital components.
Main
CPU: i7 4790 Ram: HyperX Savage 24GB DDR3 GPU: Asus Strix GTX 960 MOBO: Asus B85 Pro Gamer SSDs: HyperX Fury 120gb, Corsair Force LX 128gb HDDs: Seagate SSHD 1tb + 1tb seagate HDD CPU Cooler: BeQuiet! Pure Rock PSU: Corsair RM650x Case: Fractal Design Define C window Case fans: 2x Corsair AF140 Quiet Ed. 140mm intake, 1x Corsair AF120 Quiet Ed. 120mm exhaust
Peripherals
Monitors: 2x Asus VN247H Keyboard: Logitech G810 Orion Spectrum Mouse: Logitech G502 Proteus Spectrum Headset: Logitech G933 Artemis Spectrum Mousepad: Steelseries QcK, Corsair MM300 XXL Cables: Corsair Premium Pro Red Sleeved Lighting: Corsair Node Pro
Laptops
HP Probook G4 440
CPU: Core i3 7100u Ram: 8gb DDR4 SSD: 256gb Sandisk X4 Pro Screen: 13.3" TN
Asus E403SA
CPU: Pentium N3700 Quad Core Ram: 4gb DDR3 SSD: 128gb eMMC Screen: 14" 1080p TN
Phone:
Samsung Galaxy S8
PSU Tier List Updated    Personal Steam Account
The important thing is that you are grounded to the computer and components. If there's enough difference in charge between you and the computer, it doesn't matter much if one or the other is grounded. With that said, I've built while standing on carpet and wearing both socks and a 50/50 cotton synthetic hoodie before without any issues.
[ Intel i7-6700K ][ Asus TUF Sabertooth Mk1 Z170 ][ Gigabyte GTX 780ti ][ 32GB (2x16GB) 3200MHz G.Skill Trident Z ][ Corsair Obsidian 900D ]
[ EVGA SuperNOVA 1000 P2 80+ PLATINUM ][ 1x512GB Samsung 960 Pro M.2 (OS) ][ 3x512GB Samsung 850 Pro RAID 0 ][ 1x5TB WD Black ]
It's not about isolating yourself from the ground, it's about staying the same voltage as your electronics. You can build while furiously rubbing your feet on carpet if you like, as long as you ground to the case often enough.
duck tape that sucker to your leg and touch your case a lot, fondle it like gollum fondled the ring
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
