According to this --> http://cpu.userbenchmark.com/Compare/Intel-Core-i7-7700HQ-vs-Intel-Core-i5-4460/m211019vs2310
My current desktop CPU is slower than my laptop CPU.. is it true/possible ? also, does it mean that i better off editing video and photo from my laptop than on my PC ?
thx
https://linustechtips.com/topic/792466-mobile-cpu-faster-than-desktop-cpu/
What laptop? Needs to be well cooled, Razer Blade doesn't fall into that category :P
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
1 minute ago, agentagent47 said:
ASUS GL553VD
Pretty well built, the 7700HQ is probably better. Try a Cinebench comparison
HOLA NIGHT THEMERS
OTHER TECH I OWN:
Well yeah the 7700HQ isn't really a 'mobile' processor. It's an HQ sku intel processor which usually means 4 cores 8 threads, turbo/overclock speeds, and higher TDP.
7700HQ is basically high end laptop grade cpu while the i5-4460 is in the mid-range desktop cpu.
2 minutes ago, Lazaro said:
7700HQ is basically highest end laptop grade cpu while the i5-4460 is in the mid-range desktop cpu.
Nah, 7820HK is the highest end mobile without going "7700k in a laptop"
HOLA NIGHT THEMERS
OTHER TECH I OWN:
7 minutes ago, agentagent47 said:
So i better off edit from my laptop then ?
yeah, probably, unless you wanna pop in an i7 4790K into your mobo
HOLA NIGHT THEMERS
OTHER TECH I OWN:
9 minutes ago, agentagent47 said:
It's a B series :(
Still counts, the 4790k has a much higher base clock than a 7700hq and IPC is similar.  Add the cooling potential of a desktop and you're golden.
Want to custom loop?  Ask me more if you are curious
yup, even if you can't OC the base clock is higher than the 4790 http://cpu.userbenchmark.com/Compare/Intel-Core-i7-7700HQ-vs-Intel-Core-i7-4790K/m211019vs2384
4770K is also a good option
HOLA NIGHT THEMERS
OTHER TECH I OWN:
