Can a 3 pin fan be plugged into a 4 pin fan hub then controlled
Solved by Ithanul,
3 hours ago, F g said:do you control it with speed fan, or in the bios.
I use the BIOS for control since it just a dumb hub that passes everything to the motherboard.
Featured Topics
Bobzcpu ·
Posted in Power Supplies0 -
1
RZBAKA ·
Posted in New Builds and Planning2 -
Magnumenforce ·
Posted in Phones and Tablets1 -
1
Crash The Noise ·
Posted in Programs, Apps and Websites3 -
5
