Hey guys so I just booted up my PC and it was making weird fan whizzing noises. Sure you might think that's normal but it goes "loud , not loud , and then loud back". Now I thought it was the CPU fan but when I went to the back of my pc to open up the side panel I could hear the noise much clearer and I am obliged to think that it's the PSU. Now the PSU is nothing but a generic PSU that came with the case. But as Im writing this the noise is stable and no longer going loud and light.
Update : I took the side panel off now and now I am unclear if it's the PSU or the CPU Fan.
Update 2 : I put my ear as near as I could and concluded that IT IS THE PSU. LORD SAVE MY COMPONENTS
https://linustechtips.com/topic/791114-need-help-asap-scared-af/
Start it up again and see what is causing the noise. Could be a loose wire, loose wire getting caught, or a bad fan.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/791114-need-help-asap-scared-af/#findComment-9965688
You can stop the fan of your CPU with your hand (be careful) or just unplugged the 4/3pin and a second and hear if the noise still exist. What is your full build? It seem more likely like PSU fault.
Magical Pineapples
https://linustechtips.com/topic/791114-need-help-asap-scared-af/#findComment-9965690
Check and see if it is either, if it is the psu fan then I would suggest going easy on your pc until you can get a new one.
8086k Winner BABY!!
Main rig
CPU: R7 5800x3d (-25 all core CO 102 bclk)
Board: Gigabyte B550 AD UC
Cooler: Corsair H150i AIO
Ram: 32gb HP V10 RGB 3200 C14 (3733 C14) tuned subs
GPU: EVGA XC3 RTX 3080 (+120 core +950 mem 90% PL)
Case: Thermaltake H570 TG Snow Edition
PSU: Fractal ION Plus 760w Platinum
SSD: 1tb Teamgroup MP34  2tb Mushkin Pilot-E
Monitors: 32" Samsung Odyssey G7 (1440p 240hz), Some FHD Acer 24" VA
GFs System
CPU: E5 1660v3 (4.3ghz 1.2v)
Mobo: Gigabyte x99 UD3P
Cooler: Corsair H100i AIO
Ram: 32gb Crucial Ballistix 3600 C16 (3000 C14)
GPU: EVGA RTX 2060 Super
Case: Phanteks P400A Mesh
PSU: Seasonic Focus Plus Gold 650w
SSD: Kingston NV1 2tb
Monitors: 27" Viotek GFT27DB (1440p 144hz), Some 24" BENQ 1080p IPS
https://linustechtips.com/topic/791114-need-help-asap-scared-af/#findComment-9965693
Fan would be ramping up because of either fan failure or PSU overheating so be careful.
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/791114-need-help-asap-scared-af/#findComment-9965707
Just now, HelpMeOrIWillSuffer said:
"How do I go easy" on it, its basically on from 11 am till 2 am everyday.
dont run extremely stressful programs
8086k Winner BABY!!
Main rig
GFs System
https://linustechtips.com/topic/791114-need-help-asap-scared-af/#findComment-9965735
This.
Don't let your PSU get married either.
https://linustechtips.com/topic/791114-need-help-asap-scared-af/#findComment-9965751
Tbh all I do is either play Minecraft which is I guess "stressful" on the CPU and watch TV Shows all day long.
You might be fine until you can replace it then.
8086k Winner BABY!!
Main rig
GFs System
https://linustechtips.com/topic/791114-need-help-asap-scared-af/#findComment-9965763
20 minutes ago, HelpMeOrIWillSuffer said:
Should I open up the PSU and see whats wrong? Or should I not since I know nothing about it.
It's not like a car where you can try your hand [at] fixing things. I'd take it to a repair shop or try to RMA.
https://linustechtips.com/topic/791114-need-help-asap-scared-af/#findComment-9980652
