fan H100i V2 plastic buzzing fan noise
I have the h100i also and had some noise complaints since one of the fans has a certain rattle in it. I've read up about it and discovered this is not very uncommon so tested some stuff out with tightening/loosening the screws, feel if I could minimally bend the outskirts of the noisy fan and eventually used Corsair Link to setup a custom fan profile.
Custom fan profile what? Well although this differentiates a little from time till time, mostly only around 75% to 90% of the fan profile the rattle comes out. So after a certain temp my fan just surpasses that area to avoid any rattling at all.
Ideal solution? Far from it for such a high-end cooler. But for me it works and I can adjust it within a few clicks.
P.S. The problem does not lie in what temps are reached but more likely at how much rpm the fans are spinning. Thus the percentages mentioned above.
