Are you bound to Pscasegear or could you buy the parts from another AUS online/local store?
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
https://linustechtips.com/topic/78972-build-ideas/#findComment-1084193
my budget is 2000 to 2500 and i want the build to be as quiet as possible silence first then performance im a gamer and lite video editor, im from australia so use australian sites to get the parts
use this : http://www.pccasegear.com/index.php?main_page=index
BOOM! http://www.pccasegear.com/index.php?main_page=shopping_cart&sort=20a
Parts chosen and why:
CPU: Intel core i7 3820 - super fast, its the socket 2011 platform which is super upgradable and its the x79 platform which has tons fo pci e slots and supports quad channel and 64GB of RAM)
RAM: G. Skill Sniper F3-12800CL9Q-16GBSR 16GB (4x4GB) DDR3  - 16GB performs well, its quad channel which will give you super performance its also really cool looking and not too expensive.
Cooler: Noctua NH-U12S CPU Cooler  - easy to install, super high quality and wont get in the way of anything
GPU: ASUS GeForce GTX 770 DirectCU II OC 2GB  - quite a beast for 1080p gaming, can handle all the latest titles and can be upgraded or put in SLI in the future
SSD: Samsung 840 EVO Series 120GB SSD  - super fast super stable super cheap :D
HDD: Seagate Barracuda 2TB ST2000DM001  - got tons of room and stuff and isn't gonna break the bank
Mobo: ASUS P9X79-LE Motherboard  - got all the needed features plus more, Asus's quality and is Windows 8.1 and Ivy bridge e compatible after a BIOS update
PSU: Silverstone Strider Gold ST75F-GS 750W PSU  - Silverstone quality, super stable cause of 80+ gold and has 750w
Case: CoolerMaster CM Storm Stryker Case  - super beastly, tons of control and designed for gaming, fully upgradable and just an awesome case
OS: Microsoft Windows 7 Home Premium 64bit with SP1 OEM  - just, just... Don't get Windows 8.1 yet... causes to many problems.
EDIT:
Heres the 2,500 build which is a TOTAL beast and will pretty much handle anything lol.
https://linustechtips.com/topic/78972-build-ideas/#findComment-1084206
Good build, but we can´t view the link :/
Just wait a bit and I´ll put together another suggestion for you @Symbolz so that you can choose :)
Tor
https://linustechtips.com/topic/78972-build-ideas/#findComment-1084216
Just wait a bit and I´ll put together another suggestion for you @Symbols so that you can choose :)
Yeah, you can add the 780ti in the build which thrashes any other GPU on the market.
https://linustechtips.com/topic/78972-build-ideas/#findComment-1084226
i´m not a fan of reference coolers (Nvidias is really good, but still…) so this is my suggestion @Symbolz :)
http://au.pcpartpicker.com/p/26u7F
It is 180 AUD over budget, but it will be extremely quiet and extremely powerful :) If you can´t go higher then budget I would top the CPU to a 4770 non-K and a 770 DCU2 :)
Tor
https://linustechtips.com/topic/78972-build-ideas/#findComment-1084280
Ohh and another thing: This if from Pcpartpicker so it chooses the store where the parts are the cheapest.
You will therefore need to be shopping around from a couple of different stores...
Tor
https://linustechtips.com/topic/78972-build-ideas/#findComment-1084287
EDIT:
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor ($379.00 @ CPL Online)
CPU Cooler: Phanteks PH-TC14PE_BL 78.1 CFM CPU Cooler ($89.00 @ PCCaseGear)
Motherboard: Gigabyte GA-Z87X-D3H ATX LGA1150 Motherboard ($195.00 @ CPL Online)
Memory: G.Skill Ares Series 16GB (2 x 8GB) DDR3-1333 Memory ($169.00 @ Mwave Australia)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Disk ($188.00 @ CPL Online)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($98.00 @ CPL Online)
Video Card: XFX Radeon R9 290 4GB Video Card (2-Way CrossFire) ($475.00 @ PCCaseGear)
Case: Cooler Master Storm Enforcer ATX Mid Tower Case ($99.00 @ CPL Online)
Power Supply: Corsair RM 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($217.06 @ Mwave Australia)
Operating System: Microsoft Windows 7 Professional SP1 (OEM) (64-bit) ($159.00 @ CPL Online)
Total: $2543.06
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-11-23 00:17 EST+1100)
Why not cramp crossfire into the build?
https://linustechtips.com/topic/78972-build-ideas/#findComment-1084528
Total: $2543.06
Good question and a nice build you got there :) +1 for this ^^
Now you got three options OP :)
Tor
https://linustechtips.com/topic/78972-build-ideas/#findComment-1084579
I'd go for a 4930k + RIVE, 2x780 ti in SLI, accompanied with a >1kw psu (Strider plus 1200w perhaps). For storage a 240gb ssd (Samsung 840 pro) and a 2tb caviar green. For cooling either custom or cpu-only-kit water cooling, install these in a Define R4.
Sorry about a not-so clear post, tapatalk says hi..
Current rig: i7-5820K, R5E, 1070ti (windows), Radeon HD7850 (Mac), a bunch of SSDs and HDDs, running MacOS Mojave, Windows 10 + a bunch of debian servers on Proxmox KVM hypervisor
Laptop: MacBook Pro 13" 2017
Previous projects: Razmac G5, Server, zenbox HTPC
See my GitHub profile!
A coder/modder from Finland
https://linustechtips.com/topic/78972-build-ideas/#findComment-1093196
