I will be back in the US in one month I want to built a new rig. I have a 1000 dollar budget
I only care about it being a silent system
good for the next 4 years
light 1080p gaming
buffering 1440p videos
Productivity applications
Simple mathematical modeling
here is what I got so far
PCPartPicker part list: https://pcpartpicker.com/list/tysPWX
Price breakdown by merchant: https://pcpartpicker.com/list/tysPWX/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($209.99 @ Amazon)
Motherboard: Gigabyte - GA-AB350-GAMING 3 ATX AM4 Motherboard  ($79.99 @ Newegg)
Memory: Team - T-Force / Night Hawk 16GB (2 x 8GB) DDR4-3000 Memory  ($104.99 @ Newegg)
Storage: Kingston - Predator 240GB PCI-E Solid State Drive  ($164.99 @ Best Buy)
Video Card: MSI - GeForce GTX 1060 3GB 3GB GAMING Video Card  ($239.99 @ Amazon)
Case: Phanteks - Enthoo Pro M Tempered Glass ATX Mid Tower Case  ($74.99 @ Newegg)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($26.99 @ Newegg)
Total: $901.93
Generated by PCPartPicker 2017-06-03 21:33 EDT-0400
CPU: Intel - Core i7-8700K @4.9 GHz 6-Core Processor CPU Cooler: be quiet! - Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU CoolerMotherboard: MSI - Z370I GAMING PRO CARBON AC Mini ITX LGA1151 Motherboard Memory: PNY - Anarchy 16GB (2 x 8GB) DDR4 @3000 MemoryStorage: 960 evo 500gbVideo Card:place holderCase: Phanteks - Enthoo EVOLV ITX TG (Black) Mini ITX Desktop Case Power Supply:SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply Case Fan: be quiet! - SilentWings 3 pwm 59.5 CFM  140mm Fan Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan Monitor: Dell - S2716DG 27.0" 2560x1440 144Hz Monitor Mouse: Place holder Sony H.ear on Wireless Noise Cancelling Headphone, Charcoal Black (MDR100ABN/B)  LEOBOG K26 Wired RGB Mechanical Keyboard,Gaming Keyboard,RGB Color Backlight,104 Key,Anti-Ghosting For Full Key,Blue Switches,Aluminum Chassis,Detachable wrist rest,PC,Computer, Laptop,BLACK (Black)EZDIY-FAB Sleeved Cable - Cable extension for power supply with extra-sleeved 24 PIN 8PIN 6PIN 4+4 PIN With COMBS- Black Grey
pcpartpicker: https://pcpartpicker.com/user/resdal42/saved/sCW6XL
https://linustechtips.com/topic/788427-need-a-1000-dollars-pc-built/
get the 8gb 580 the 3gb version of the 1060 isnt really worth it
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
11 minutes ago, IAnthonyFX said:
Snip
You're overpaying for your GPU. get a 1060 6GB or RX 580 8GB. the 1060 3GB not only has less VRAM, but also trimmed down CUDA count so you will get less performance. You can get a 1060 6GB easily for the same price you're paying for that 3GB (same for the RX 580 8GB)
Also your choice of SSD.... don't get that one. Get this instead. Its much faster, slightly larger, and much cheaper... not to mention it fits nicely into your motherboard's M.2 slot for a clean look and easy setup/installation, rather than interfering with a PCIe slot: https://pcpartpicker.com/product/ZNBrxr/samsung-960-evo-250gb-m2-2280-solid-state-drive-mz-v6e250
other than those minor gripes it lookse fine. I might suggest other minor changes (such as a motherboard with USB C) but without knowing what is important to you or what is worth paying for in your opinion, its difficult to really make a strong recommendation.
PCPartPicker part list: https://pcpartpicker.com/list/BBzWTH
Price breakdown by merchant: https://pcpartpicker.com/list/BBzWTH/by_merchant/
CPU: Intel - Core i5-7600 3.5GHz Quad-Core Processor  ($208.89 @ SuperBiiz)
Motherboard: ASRock - B250M-HDV Micro ATX LGA1151 Motherboard  ($62.99 @ SuperBiiz)
Memory: Crucial - 8GB (1 x 8GB) DDR4-2133 Memory  ($57.33 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.44 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card  ($244.99 @ SuperBiiz)
Case: Corsair - SPEC-03 Red ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: EVGA - 500W 80+ Certified ATX Power Supply  ($35.54 @ Amazon)
Wireless Network Adapter: TP-Link - TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter  ($16.75 @ OutletPC)
Monitor: Asus - VP228H 21.5" 1920x1080 60Hz Monitor  ($109.00 @ Best Buy)
Keyboard: Redragon - S101 Wired Gaming Keyboard w/Optical Mouse  ($24.99 @ Amazon)
Total: $868.91
Generated by PCPartPicker 2017-06-03 21:47 EDT-0400
This is my build and disregard the keyboard, monitor, etc. and add another ram stick and I think you're good to go
The 3gb 1060 is sufficient but the 6gb 1060 is marginally more expensive and much better performance
got this so far, thanks for your replies guys
PCPartPicker part list: https://pcpartpicker.com/list/kscFnn
Price breakdown by merchant: https://pcpartpicker.com/list/kscFnn/by_merchant/
Storage: Samsung - 960 EVO 250GB M.2-2280 Solid State Drive  ($127.99 @ Amazon)
Video Card: MSI - Radeon RX 580 8GB GAMING X Video Card  ($254.99 @ SuperBiiz)
Total: $879.93
Generated by PCPartPicker 2017-06-03 21:50 EDT-0400
Total: $868.91
ummmmm ryzen 5 is about the same in gaming but destroys the i5 in multi core
Peripherals
Total: $879.93
Looks good. if you want to spend more you should seek more storage (250GB isn't a lot) so maybe add an HDD to the build. You could also increase the PSU wattage if you plan to keep it through more than 1 build or upgrade this down the road. If you don't want to do either of those things, you could always step up the CPU or GPU.
I'm not the biggest amd fan but I appreciate the info. and I'll look into it. Ryzen seems pretty interesting but I've used Intel all my life and so far for me it has worked pretty well.
But I'll look into Ryzen. Thanks man!
I am a bit confused, is the extra $100 you left on your post for an OS, or is $1000 for the build only, not the OS too? because everyone is limiting the price to $900 usd it seems...
OP, just buy a 1070 with your current build posted with a seasonic 520w PSU and that wull be fine.
What productivity applications? CAD (prefers speed), Premiere (prefers core count), or Word (prefers disk?)?
Cor Caeruleus Reborn v6
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Total: $879.93
This is solid.
i dont need a 1070, but the 1000 is for the pc only. I get a win 10 copy from my college.
6 minutes ago, Starelementpoke said:
This is solid.
A 500watt+ PSU could be good for future expanding.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
Motherboard: Gigabyte - GA-AB350-GAMING 3 ATX AM4 Motherboard  ($99.99 @ Newegg)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive  ($99.88 @ OutletPC)
Video Card: Sapphire - Radeon RX 580 4GB PULSE Video Card  ($206.99 @ SuperBiiz)
Case: Phanteks - ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case  ($99.98 @ Newegg)
Power Supply: EVGA - SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.87 @ Amazon)
Total: $950.13
Put the P400S in because the Enthoo Pro M TG seems to have disappeared from PCPP lol, get the Enthoo Pro M instead if that's your preferred case though. I'm almost certain the P400S and Enthoo Pro M have the exact same interior layout, other than the fact the Pro M has a 5.25" drive bay.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
