Custom Water Loop?
Solved by Derangel,
Okay, but if I decided to go with compression fittings it would be better, or equivalent to go with 3/4"? Also those 2 measurements you see on tubing on Amazon and such, is that just the measurements of the outer diameter and inner diameter? I'm guessing that's what ID and OD stand for.
The size of the tubing determines the amount of water that flows through it. It really isn't as important these days and especially not for beginners. 7/16th, 1/2, and 3/8ths are the big ones you will see and it is good to stick with one of them.
Correct. With barbs you really only need to worry about the ID but with compression fittings you need to look at both.
